Steering wheel angle. | FerrariChat
Discussion in 'Technical Q&A' started by 456 koirra, Mar 7, 2007.
  1. 456 koirra
    456 koirra Karting
    Aug 18, 2005
    95
    Finland
    The steering wheel on my 456 GT has had a slight angle ever since I bought it but it would surely be about time to get it straight.
    Can I do that somehow myself by removing the steering wheel and so on or do I have to get that done in a special shop? Almost any shop adjusting wheel angles or at Ferrari?
    The car steers very good and tyres wear even.
    Thanks, all info appreciated.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If you mean that the wheel is slightly rotated when going straight ahead this is a simple fix. It could however indicate that someone has bumped a curb a bit hard and knocked the alignment off. For this you will need to put it on an alignment rack and check it. Then it will be a simple adjustment to put it back straight (assuming that no parts are damaged) essentially lengthen one tie rod and shorten the other an equal amount until the wheel is centered.
    If you were referring to something else, never mind.
  3. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Often steering wheels are a little off during the initial wheel alignment at the factory. It is rarely off enough as a whole notch on the steering column. The only way to straighten it is to adjust both steering tie rod ends in the same direction a part of a turn. It must be exact or you will change the toe in. It is not difficult per say but not easy either.
    aehaas
  4. chris marsh
    chris marsh F1 Veteran
    5,760
    Detroit
    Chris Marsh
    I did hit a curb and threw mine off a little. Took it to an aligment shop and they said they did some adjustment but it was still off straight maybe 5-10 degrees. I adjusted back to central the way Mr, Haas described. Then in december I had the suspension bushings replaced and the dealer did an eloborate alignment and provided me with the before and after specifications. Funny thing the steering wheel was off that exact same 5-10 degrees. So I adjusted it back. Not only did I put a paint mark on the tie rods but I double checked toe-in with the string method.
    Any Ideas what if anything might be wrong to cause this?
  5. f355spider
    f355spider F1 World Champ
    18,053
    I've watched a local race shop near me do an alignment. They make sure the wheel is straight, then attach a bar or something that holds it in position. Then they make the adjustments as AEHaas describes. This way the wheel will be perfectly straight ahead.
  6. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    You must carry out a 4 wheel alignment.
    Your steering wheel could be off due to a REAR end problem... and checking/adjusting the front only may induce a "crab" in the car.
    The car must be placed in a perfect square and measured all round.
  7. Etcetera
    Etcetera Two Time F1 World Champ
    24,159
    C6H14O5
    Just pull the steering wheel off and re-center it. No point in doing all this monkey bidness with wheels and tire odd ends.
  8. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    And you can't just pull the wheel off and centre it.. you need to preserve the steering lock position as the wheel is straight ahead, also indicator self cancel function, you also (and this is a VERY common thing to be done wrong) need to preserve steering column joint alignment.. the UJ's must be perfectly aligned (like a tailshaft) to maintain constant velocity upon turning....
    Look down into your lower steering column area/footwell on anything from 355 and later pretty much.... you'll see two great big white paint marks on bits of the column... These must be aligned to each other. But not just on the sliding section either.. the UJ's themselves must be perfectly aligned as they are removable.
    I've seen way too many cars with supposedly reputable history that have a misaligned column.
    This causes vague and inconsistent steering feelings... you get artificial "weight" of steering, as the joints load against each other... which also promotes wear and further vagueness....
    You also need to preserve steering rack centralisation...
    count the turns from lock to lock... half way should be straight ahead... of course, you say!.... Try it... !
  9. 456 koirra
    456 koirra Karting
    Aug 18, 2005
    95
    Finland
    In the weekend I played around a bit with the steering. I did not find the big white marks on the steering column from the 456 GT so I took of the steering wheel just to give it a shot but looks like I have to take it to shop to get it sorted.
    Ferrarifixer: sorry, I am a novice, what are UJ's?
    Thank you all for the fantastic response!
    Every opinion is greatly appreciated to get the wide range of possibilies of what one could try and that there are no F car specialities involved.
  10. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    UJ's are universal joints.
    The spider or cross in the middle must be in perfect alignment to ensure constant velocity while rotated.
    same principle as tailshafts, or propellor shafts whatever...
    http://en.wikipedia.org/wiki/Universal_joint
