Steering Wheel Centering | FerrariChat
Discussion in '360/430' started by michaelo, Jul 11, 2007.
  1. michaelo
    michaelo Formula Junior
    385
    Tn.
    Michael O.
    I had an alignment done at Ferrari of Atlanta on Monday, with the hopes of centering the steering wheel. It is cenetered at 11:00. I picked up the car, and though it tracks beautifully, the steering wheel is still at 11:00. I have a local shop in Nashville that is looking into removing the steering wheel and centering it. I know that there is an airbag to deal with. Anyone here have any experrience with this? Would appreciate some input. Thanks.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Its very easy to do, just make sure the battery isolator switch is turned off before removing airbag. There are notches in the steering wheel (like a sprocket) and its no doubt at some point been removed and then re-affixed back onto the car, they unfortunately didnt check the centring before tightening it. Very easy to do and should take no more than 20 mins.
  3. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    I don't know if I would opt for the steering wheel option or simply adjusting the toe on both side equally. If the wheel is still at 11:00 that means you need to bring the left wheel out and the right wheel in equal amounts. It's as simple as jacking the car up and loosening the tie bar screw and turning it equally a quarter turn on both sides (out on the left and in on the right). This will not mess up your alignment. It will straighten your steering wheel.
