steering wheel/column position | FerrariChat
Discussion in '308/328' started by jtower, Dec 14, 2007.
  1. jtower
    jtower Rookie
    Dec 1, 2007
    21
    raleigh, nc
    jason tower
    i test drove an 85 308qv recently and had a very difficult time getting positioned in the car. if i moved the seat forward enough to fully depress the clutch pedal my knees (esp left) were smacking hard into the bottom of the steering wheel. the top of the steering wheel also was right in the middle of my line of vision to the tach and speedo makng it impossible for me to read speed or revs with tilting my head awkwardly.
    later that afternoon i stopped by a local ferrari shop and sat in another 308qv (and a 328 as well), both were far more comfortable - i could hit the pedals fine without banging my knees (although it was close) and the top of the steering wheel was just above the complete tach and speedo.
    it's as if the entire steering column in the first 308 was too low or angled downward to a significant degree. is this possible without the car being damaged somehow? i don't recall that the steering column was adjustable in any way.
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,136
    E ' ' '/ F
    Snike Fingersmith
    The column is adjustable to a degree, there's no lever like more modern cars but the bolts can be loosened and the positioned shifted up/down slightly.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    You can always go with a smaller steering wheel.
  4. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Melbourne, Australia
    Brett
    Welcome to the world of 308's.
    Designed for Italian's. Long arms and short legs.
    What I have had done is push the seat all the way back then have a spacer (Aluminium) put in under the steering wheel (25mm thick). I'm 186cm and that has worked fine for me. Not sure if your hieght, but 308's are tight.
  5. ferrari_rich
    ferrari_rich Karting
    Oct 1, 2006
    117
    Southampton, NY
    Rich
    I found that by adjusting both the seat back angle, as well as the steering wheel angle (remove lower cover to get to adjustment), my 6 foot tall frame fits easily in the 308, with plenty of headroom. The seat back angle has a lot to do with the headroom, and I still have a couple of notches of seat travel to the rear left. I have long legs and find it a comfortable car. Not as comfortable as my Porsche 944S, which fits like a glove, and by far the most comfortable cockpit of any car I have driven.
    I do have a pet peeve about people (mechanics) adjusting my seat! It takes me a while to find my exact position back. So, NOBODY screw with my seat adjustment!!!!
  6. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    Sounds like the steering wheel is at the bottom of its adjustment. Most people like it up high like the others you sat in. If you have a manual, it shows how to adjust. It only takes a few minutes. I also use a spacer in my steering wheel (328).
    Dave
  7. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Ditto on the spacer. That made the difference.
  8. jtower
    jtower Rookie
    Dec 1, 2007
    21
    raleigh, nc
    jason tower
    thanks for the replies. so the concensus is that the steering column *is* adjustable vertically, albeit with tools? if so that would probably explain things.
