Steering Wheel Tilt | FerrariChat
Steering Wheel Tilt
Discussion in '308/328' started by Low Ride, Feb 22, 2010.
  1. Low Ride
    Low Ride Karting
    Jan 20, 2010
    65
    Ontario, Canada
    Guido Benvenuto
    I have recently purchased an '81 308 and can't possibly be more pleased with this car. The only thing I am not crazy about is that the steering wheel seems to be tilted too high for my taste. I noticed a bolt and nut on the botton in a slot and thought that I could adjust the tilt by loosening but no luck. Does anybody know if there is a way to change the angle of the wheel slightly?
    lkb229 likes this.
  2. Steve Magnusson
    27,024
    #2 Steve Magnusson, Feb 22, 2010
  3. Low Ride
    Low Ride Karting
    Jan 20, 2010
    65
    Ontario, Canada
    Guido Benvenuto
    I see the nut and bolt you point out in your reply. Is this a normal thing to do? Or is it intended to be in the current position?
  4. Steve Magnusson
    27,024
    #4 Steve Magnusson, Feb 22, 2010
    It's meant to be adjusted as desired -- nothing sacred about its "current position". Often, they get adjusted into the (horrible ;)) "full up" tilt position to give more clearance underneath the steering wheel rim to aid ingress/egress. My preference was to add a 2" spacer between the steering wheel and the steering wheel hub, go to a 320 mm diameter steering wheel, and go to the "full down" tilt position:
  5. Low Ride
    Low Ride Karting
    Jan 20, 2010
    65
    Ontario, Canada
    Guido Benvenuto
    I will certainly give this later this week and see what I come up with. I see what you mean about the clearance to get in and out of the car. Thanks for the help!
  6. flavioleon
    flavioleon Karting
    Dec 21, 2015
    80
    Italy
    Flavio
    #6 flavioleon, Feb 6, 2016
  7. lucky strike
    lucky strike Formula Junior
    Apr 26, 2015
    472
    Pompano Beach Fl
    Steve
    Interesting
  8. flavioleon
    flavioleon Karting
    Dec 21, 2015
    80
    Italy
    Flavio
    I found it ........ n^36
    I moved down the steering wheel .... Perfect setting
  9. 83911SCDrew
    83911SCDrew Karting
    Oct 21, 2018
    96
    Bernardsville
    Andrew K
    Image Unavailable, Please Login Old thread but went with Steve’s recommendation - 2” spacer (50mm) and full tilt down. I’m 6’4” and a big guy, and this gives me a nearly perfect steering wheel position (bottom of palm arm fully extended is just over the top of the steering wheel. Safer this way in the event of a crash, not having arms fully locked and extended forward.
  10. mwr4440
    58,203
    Bavaria, The 'Other' Germany
    Mark W.R.
    Where you guys getting the 2" Spacers?
    I got a Nardi.
  11. Steve Magnusson
    27,024
    You could get the 50mm MOMO Hill Engineering spacer SWS02B from Ricambi America and then add a thin MOMO-to-Nardi Adapter (if you can't find a direct 2" Nardi extension).
    absostone likes this.
  12. Vonbarron
    Vonbarron Formula 3
    2,300
    Westside Mofo
    S B
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    First time in 35 years I've ever heard of this as "adjustable". Haven't seen it mentioned as such in any manual.
    Kent Dellenbusch likes this.
