Stereo iPod connection?? | Page 2 | FerrariChat
Discussion in '456/550/575' started by Rubi, Jun 22, 2009.
  1. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Thanks - an interesting idea. I don't care that much about the CD changer once I have an iPod although I guess the sound is better from a CD. My car is at dealer now. Will get it back at the end of the week and will let you know the serial number.
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    I don't need your serial number, what I meant was that if the Becker model number is higher that 7XXX an Ipod interface with full functionality is available, otherwise its just charging and audio. Charging is not available with Nano 4G
  3. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Thx
  4. SciFrog
    SciFrog Formula Junior
    Apr 9, 2008
    566
    Can all this help for my 05 612 with a Becker unit and CD changer?
  5. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    I finally finished my project, now I can toggle between the Ipod and the CD changer with the unused rear fog light switch on the dash.
    Only thing is I have to cycle the radio off and back on to get it to recognize the CD changer, why that is I don't understand, if I don't cycle the radio it does it itself in about 5 minutes.... Bizarre.
  6. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    My model number is Becker BE7860. If it is of any relevance, my serial number is 20027496. My car is a 2004 575HGTC.
  7. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Something very funny on page 93 of the owner's manual for the stereo, Sockets C2 and C3 have specified pins for "special connection for Porsche CD changer". Someone in Italy failed on the global "search and replace" when finalising the manual!!!
  8. Sir Paul
    Sir Paul Formula Junior
    Feb 22, 2008
    537
    HONG KONG
    I think the BE7860 is the Becker Silverstone CD Changer unit and the Radio Head is possibly the BE6104. Not sure which needs to be the 7XXX number to use the new er Becker iPod Interface.
    PAUL
  9. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
  10. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,654
    South East
    Jimmie
    Brief question not really worthy of its own thread :
    Using a basic ipod cable in the back of an original Becker 4372 are there any easy / recommended places on a 575 to connect the power & earth (+/-) leads to facilitate charging ?
  11. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    The charging wire are in the basic cable, just plug it in the back of the Becker where the CD player connector was. It will charge even with the key off.
  12. greyboxer
    Dec 8, 2004
    12,654
    South East
    Jimmie
    #37 greyboxer, Aug 22, 2009
    Thanks rapid reply but I may not have described my cable fully - it has the block to go on the back of the Becker but only for the sound signal but two loose wires for the charging (unlike for example the much more expensive cable mentioned elsewhere that does include the power supply) hence the query for suggestions of where to pick up the power & earth
  13. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    #38 ferraridriver, Aug 22, 2009
    Need some more info. What color are the blocks you have?
    The blue connector with three wires is the audio connection, the green connector with two wires is the power 12V +&-
    Do the two wires you have have ends crimped on? If so I might have a green connector you could use, just push your wires in if they have ends crimped on.
    BTW, the connectors are all different and will only fit in the Becker the correct way round.
    This is the cable you want, $65 on eBay from Beckerautosoumd
  14. greyboxer
    Dec 8, 2004
    12,654
    South East
    Jimmie
    #39 greyboxer, Aug 22, 2009
  15. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    OK...In the mess of wires going to the radio there is a black plastic two wire connector about a quarter inch square, maybe an inch long, with red and black wires. Its the only loom that has only two wires.
    Just tap into those two wires matching colors, but first, and very important, check them with a meter or test light.
    They should be Red, always hot and Black, ground.
    I'm almost positive that they are red and black, but it may be red with a black tracer and black.
    That should do it for you
  16. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    I have just fitted the Beckerautosound cable and am absolutely happy. Hasslefree. Once I programmed playlists into my iPod the lack of control from the headunit is no big deal.
  17. Sir Paul
    Feb 22, 2008
    537
    HONG KONG
    I got my Beckerautosound cable yesterday and fitted it last night. Very easy, using the Becker keys to remove the radio then just plugged cable in and set AUX input to "on" in the Radio programming section.
    Currently the cable comes out from the front under the dashboard, but ultimately want it to come out of the back of tunnel. I understand DM did his that way but needs trim removing to thread through.
    I will leave that sort of work for when it goes in for next service.
    Meantime, very happy with the way my iPod works through the BE 6104 Radio Head and this new cable.
    PAUL
  18. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    Where is the trigger wire on a 456? I get great fm but total static on am.
    Dennis
  19. tazandjan
    39,117
    Dennis- Call Scott and ask:
    La Jolla Audio
    Scott Cairncross
    5161 Santa Fe Street Ste B
    San Diego, CA 92109
    858-581-6545
    858-581-0360
  20. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    Thanks Taz.
    Dennis
  21. 1986Tr
    1986Tr Rookie
    Jan 17, 2015
    41
    #46 1986Tr, Mar 5, 2015
    HI Dennis,
    it is pin 5 on the power plug... I have to correct this problem all the time! Be careful who does your install. The other common problem is a bad antenna adapter cable... @ 15% failure rate...
    Scott LJA
  22. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    Thanks Scott.
    You are most kind in getting back to me.
    Dennis
