Stereo trouble | FerrariChat
Stereo trouble
Discussion in '360/430' started by Texasrecurve, Mar 2, 2017.
  1. Texasrecurve
    Texasrecurve Karting
    Oct 15, 2006
    150
    Graham, Texas
    Rodney D. Mitchell
    I have a new-to-me 430 that has had an Alpine system installed at some time in the past. It has the upgraded factory sub woofer. The head unit powers up no problem, when you put in a CD you can tell it is working correctly, but no sound from any speaker no matter the source. The problem is I live 100 miles from any metropolitan area, i.e.: anyone who has ever seen a Ferrari much less tracked down a stereo problem in one. I am understandably very hesitant to take it to just any stereo shop and would love to find what I am sure is a simple problem and fix it myself. Any ideas where to start and what to look for? Thanks.
  2. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    Please clarify... only the CD player lacks audio? AM/FM radio is OK?
    Or no audio at all?
    Check the head unit's wiring connectors.. could be the plug linking all the audio signals is disconnected.
    I'm not sure whether it is possible to look under the dash or whether the head unit has to be pulled. You have the puller tools, right?
  3. gobuffs2002
    gobuffs2002 Karting
    Aug 7, 2010
    242
    Colorado
    I had a similar problem with my 360. It turned out to be the drivers door speaker shorting to ground. Apparently if a ground is detected by the amp, the radio will shut the amps down to prevent any damage to the radio.
    Sent from my SM-N920V using Tapatalk
  4. Texasrecurve
    Oct 15, 2006
    150
    Graham, Texas
    Rodney D. Mitchell
    Thanks, I don't have any sound at all....AM/FM CD, doesn't matter. I don't have any puller tools but maybe I can get under the dash to make sure everything is plugged in. I had someone else also tell me that if 1 wire to any of the speakers is shorting out then I would get no sound. What a pain trying to find that.
  5. gobuffs2002
    gobuffs2002 Karting
    Aug 7, 2010
    242
    Colorado
    I would focus on the door panel speakers. Easy enough to do. Pull the trim on the door panel. Unplug each speaker and see if you get sound. I would draft with the drivers door because it's always getting open and closed.
  6. Caeruleus11
    Caeruleus11 F1 World Champ
    11,620
    When you turn the volume up, do you hear more static or do you hear no change?
  7. 911-AL
    911-AL Karting
    159
    Chicago
    My friends call me Al!
    Do you have the HIFI option with the amp mounted under the dash. Mine was doing nearly the same thing and it turned out to be my amp was shot (Be sure to check the fuse first on the amp). I replaced it and it started working right away.
    If no HIFI option, is there an aftermarket amp mounted somewhere in the cabin or in the trunk? If so, check the fuse. Could be that easy.
    Al
  8. Texasrecurve
    Oct 15, 2006
    150
    Graham, Texas
    Rodney D. Mitchell
    When I turn the volume up I continue to get nothing but silence, no static, nothing. I do have the HIFI option with the amp under the dash. Thanks 911, I'll track down the fuse first and check that.
