Stickier tires for a 430? | FerrariChat
Discussion in '360/430' started by prg, Jun 16, 2009.
  1. prg
    prg Rookie
    Feb 17, 2004
    30
    oklahoma
    Hello,
    Wanted to know if anyone has fitted any streetable R-compound or near R-compound tires to their 430. I'd like a little more grip. I have no desire to put on aftermarket wheels to fit larger rubber. Rain performance is a non issue for me. The only R-compound tires I saw on tire rack in 430 sizes were the $500+ corsa system tires for the Scuderia.
    Anybody found anything else in stock sizes.
    Thanks,
    Patrick
  2. TimsBlack16M
    TimsBlack16M Formula 3
    Jan 27, 2005
    1,365
    Agoura Hills, CA
    Tim
    I used the corsa system on my 07' F430 Spider, and saw a sustantial improvement versus stock. Ferrari uses them as OEM on the Scud and Stradale for good reason!
    Tim
  3. prg
    prg Rookie
    Feb 17, 2004
    30
    oklahoma
    #3 prg, Jun 17, 2009
    Thanks for your response Tim,
    Did you notice a worse ride with the corsa's? I noticed in the Michelins on the Porsches that the pilot sport cups had better grip than the PS2's, but stiffer sidewalls with some loss of ride quality. I don't have any intention of tracking the car. I'd like some improvement in grip, but I don't want to make the car unpleasant to drive over the very imperfect roads of rural Oklahoma.
    I was hoping there might be some other options, but I think I'm just going to get the corsa's.
    Thanks,
    Patrick
  4. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Hey,
    Not sure on the sizes, but you may want to check out the Toyo R888's - I put 'em on my 360 and *all* the tire squeal went away.
    Cheers,
    Ian
  5. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    The Corsa system is good for the street but not great for the track. I track my CS regularly and have been looking for a track tire but there isn't one. The R888 does not fit.
  6. TimsBlack16M
    Jan 27, 2005
    1,365
    Agoura Hills, CA
    Tim
    The ride comfort was similar to the original tires. The only negative was that the tire road noise was marginally louder (but, not bothersome). The traction and handling limits (after warming up) were dramatically improved.
    Tim
  7. prg
    prg Rookie
    Feb 17, 2004
    30
    oklahoma
    Thanks for all the responses.
    Corsas it is.
  8. duncan1165
    duncan1165 Rookie
    Jun 18, 2009
    25
    I have found the Michelins Cup Sports to be quicker in the dry and the Corsa better in the wet. The Michelins to go off a little quicker unfortunately.
  9. prg
    prg Rookie
    Feb 17, 2004
    30
    oklahoma
    I don't see the sport cups in stock 430 sizes. Are you using a different size on the stock 430 wheels? aftermarket wheels? Have you found them somewhere in stock sizes?
    Thanks,
    Patrick
  10. tazandjan
    39,191
  11. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    I have wider NEEZ Mg wheels 19" with rear 305 MPSC and ther work very nice I also have MPSC 20" 315 rear and the car handles very good with this tires (Better with 19")
    OEM rear 285 is ridiculous and 225 front too (I use 235 front) in this wheels I use Bridgestone RE050 and they work great too TW 140,Cup or Carsa are better TW 80 and TW 60 .
    You will be happy with Corsas
