Sticking Water Temp Gauge ? | FerrariChat
Discussion in '308/328' started by smss26, Sep 21, 2008.
  1. smss26
    smss26 Karting
    Nov 19, 2006
    92
    Glastonbury, CT
    Stephen Spencer
    The gauge seems to work fine initially (and I have a new sensor on the coolant tank), but when I hit a bump on the road it buries itself up at 250. A tap on the guage would bring it back down around 195, but more recently it will pop up to 250 and stays there. Any ideas before I pull the faceplate and check the connections?
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Not unusual at all.
    Typically I see oil pressure gauges that stay at zero until you tap on them as well.
    These instruments are not the best. I suspect that "if it wasn't for low-quality, there would be none." ;)
  3. smss26
    smss26 Karting
    Nov 19, 2006
    92
    Glastonbury, CT
    Stephen Spencer
    It used to work just fine - I know they're only supposed to provide us a "general indication" of what's actually happening, but..........
  4. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    Just 5 months ago I had the same problem after I had a service done,so I knew I wasn't over heating,I took the gauge out and rotated it from left to right,and watched the needle to follow,lay the guage face down wait and then look at it if the needle moves from 250 to 0 and it takes a few seconds there's a spring broke inside,I bought a guage out of a 308qv that www.ferrparts.com was parting out for $75 and now it works like it should (not tapping on it everytime to get a reading),but most here will say its the connections but that wasn't my case,also go back on past post on this,
  5. smss26
    smss26 Karting
    Nov 19, 2006
    92
    Glastonbury, CT
    Stephen Spencer
    I think the gauge is shot - nothing at ferrparts.com, no luck at Rutlands....any ideas?
  6. Steve Magnusson
    26,932
  7. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    did you call or checked on the website,I know their parting out two 308's and one is a qv
  8. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
  9. f355spider
    f355spider F1 World Champ
    18,055
    These guys http://www.paspeedo.com/ fixed my 308 clock, and later my 328 clock and my 328 tach. They can certainly fix your water temp gauge.
  10. smss26
    smss26 Karting
    Nov 19, 2006
    92
    Glastonbury, CT
    Stephen Spencer
    I spoke with John at Rutlands - no luck. The search continues.....
  11. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    but did you call patrick at ferrparts? I don't think you did!
