Sticky door... | FerrariChat
Sticky door...
Discussion in '206/246' started by MRONY, Jun 15, 2007.
  1. MRONY
    MRONY Formula Junior
    Mar 17, 2007
    707
    New York City
    Mike O.
    The driver's side door is a bit sticky -- sometimes I have to reach inside and pull up on the ledge to open it...not every time, though. It closes smoothly, nice and tight, & does not rattle at all. Would welcome an opinion as to whether this most likely a hinge issue or a latch issue.
  2. Italian Lover
    Italian Lover Formula Junior
    Oct 26, 2006
    553
    Italian Lover
    I had a similar problem w/ mine. Somehow, opening/closing was "sticky". Took it to a shop and had the hinge area replated. My assumption is that previous owners used the door as support when getting out of car, thus applying unduly weight to the door hinge. (Most likely the passenger side door is free from the same problem). After this minor repair, it is much better. I do not put my weight at the door when I get out, instead I use the door sill for support. Jimmy
