News
Sticky : Mondial 8/QV/3.2/t Repair thread
Discussion in 'Mondial' started by enzo52, Aug 20, 2008.
  1. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    LouisvilleKY/Switzld
    Randall Gatz
    Dear Guido,
    I assume because of your answer that the Porsche part number for the 348 boot is different than that which fits the Mondial??
    Randall
  2. theunissenguido
    theunissenguido Formula 3
    Silver Subscribed Owner
    Jan 21, 2004
    1,496
    Argent/Brasil/Blgium
    Guido
    The number porsche 90133229312 Fits:
    Porsche 911 1969-75
    Porsche 911 TURBO 3.0/3.3L
    I dont know those diameters from this boot.
    The boot that fits mondial is Porsche 1984-1989 nr 92833292402. Diameters 68 mm and 28 mm. Fits also 328. See Dave gt4 article on Birdman webside.
    Guido
  3. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
    Are they really Fiat lights? If so do you have the reference? I would love to replace mine. One of them has been replaced but it is neither Ferrari nor Fiat. Any comments would be appreciated.
  4. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
  5. mikael82
    mikael82 Formula Junior
    845
    Finland
    Mikael
    #30 mikael82, Nov 8, 2011
    It was from some old Alfa and Fiat, common Fiat group part, sorry I do not remember.
    Few minute search; Alfa GTV6 1981-1986 and Alfa Spider 1983-1990
    (Some one please comfirm those)
  6. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
  7. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
    #32 porphy, Nov 15, 2011
    I have found a source for braided oil lines.
    The part shown is the lower braided oil line from the engine to the oil cooler on a Mondial T.
    Any other braided oil line can be made. It looks good and the welds look OK. This example shown is with painted high carbon steel connectors and is $295. Stainless connectors are a bit more expensive. Contact for this is:
    Craig Williams
    Fabricated Flex & Hose Supply
    2037 Palmer Ave.
    Kalamazoo, MI 49001
    Phone 269-342-2221
    craig.w@fabflexhose.com
  8. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
  9. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
  10. porphy
    porphy Formula 3
    Dec 9, 2009
    1,171
    Randall Gatz
    These are the original license plate light for at least the Mondial T. I think they also fit earlier models. Carello finally delivered. There is also one on ebay. Search Alfa GTV-6 license plate lights.
  11. theunissenguido
    Jan 21, 2004
    1,496
    Guido
    #37 theunissenguido, Jul 27, 2012
    07-15-2012, 03:40 AM
    godabitibi
    Formula Junior
    Silver Subscribed Join Date: Jan 2012
    Full Name: Claude Laforest
    Headlight switch problem fixed
    When I bought the car Stephane told me that to turn the lights ON you only have to go half the rotation with the switch for the light to stay ON. When the car arrived I tried them and hummmmm, strange. If you turn the know to full ON position the lights would turn off again. So today I decided I was looking at this problem. So I removed the rotating knob off the stalk. There is a retaining ring that you just pry off and then you can slide the knob off the stalk. Be CAREFULL there is a small detend ball and a spring and you don't want to loose them.
    At the bottom of the knob hole is a cam that operates the switch in separating the two copper blades to open(turn off) the circuit. At first I tought the cam in some way might have been place in the wrong position by someone in a previous repair. But couldn't see how. After a closer inspection I found the black wire was unsoldered from the blade. It was probably forced to touch when the swith was hafl way but released when in full position.
    I resoldered the wire in place taking care not to heat/melt the plastic by cooling it with a wet rag while soldering. Put everything back in place and it was working like it should.
    Little things that makes the car better everyday!
  12. theunissenguido
    Jan 21, 2004
    1,496
    Guido
    #38 theunissenguido, Jan 11, 2016
    The first fuseboxes I make, I used the old connectors (see thread in Sticky mondial repair)
    The NEW fuseboxes have bigger connectors for relais, fuses and where the wires are connected.
    Relais connectors have 2 pins (2.5 mm2) instead of the 1 (1.5 mm2) ;
    Fuse connectors are for the new model fuses ;
    Wire connectors are much bigger with bigger pins. Because of the bigger connectors they are turned 90 degrees and therefor the white plastic connector holders have to be cut a little. This can be done with a dremel.
    Fuseboxes are available for ALL mondials, testarossa, 328, 400 series and F40.
    For more information PM me or send me your email : theunissenguido@hotmail.com
  13. Alden
    Alden F1 Rookie
    Rossa Subscribed Owner
    Apr 25, 2010
    2,706
    Central Florida
  14. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    Georgia Mountains US
    David Rapalyea alias
    You may qualify in time for a Nobel Prize of one sort or another. The world is a better place for diligent people. I am confident in this because I am a resolutly un-diligent person and know of what I speak.
  15. theunissenguido
    Jan 21, 2004
    1,496
    Guido
  16. MvT
    MvT F1 Rookie
    3,776
    The Netherlands - NH
    Tijn
  17. Alden
    Alden F1 Rookie
    Apr 25, 2010
    2,706
    Central Florida
    How can we make this a true "sticky" again? Mods?
    Alden
  18. enzo52
    enzo52 Karting
    Aug 14, 2008
    115
    France, Paris
    Depensadie Seraphin
  19. MvT
    MvT F1 Rookie
    3,776
    Tijn
