Guys, Is there anything that could clean the sticky interior parts in the 355? I am trying to avoid the expensive overlays... Thanks, Francisco
Use the search function(upper left corner pull down menu). There are many threads devoted to this subject. Steve
I cleaned all my sticky parts about 2.5 months ago at a total cost to me of $12.42 and 10 hours of labor. The products you need are: Isoporpyl alcohol (91% or greater), que-tips, paper towels, time.
Mitch is spot on but it's not an easy job. If I were to do it again, I would make it much easier and simply put the products in a box and send them to Robbie at Stickynomore.
+1, lots of rags and lots of easy off oven cleaner! I always enjoy the DIY solutions, but it's great to have Robbie offering the service.
Most of them I left in plastic. A couple I gave a light coat of flat black paint--these, also, had some "body work" done to them to fix cracks and divots. I use 5 minute epoxy and typical modeling skills.
You lucked out---Most plastic does not look good enough to leave as is once the coating is removed. Ferrari uses crap plastic...
