Sticky parts to much info just an answer please | FerrariChat
Discussion in '348/355' started by ERICZZ, Jul 4, 2006.
  1. ERICZZ
    ERICZZ Karting
    Aug 26, 2005
    127
    New Hartford
    ERIC Z
    Ok all was fine until today humid and I cleaned the interior with a cleaner then conditioner and walla I now have the sticky's . I removed everything and will await a few answered before I proceed . I have heard dishwasher , goof off 2 ,and oven cleaner . What is BEST ! . I will then just trimblack them I just want to get the mess off first . I cleaned one mirror triangle with some general purpose cleaner with success but took to long .
  2. ecoloqua
    ecoloqua Karting
    Mar 15, 2006
    148
    You should never clean your stock plastic interior parts with any solvent because they are ridiculousy fragile and scratch easy. Being that it is too late for that in your situation here is what you can do.
    First remove all the sticky parts. Place them in a mud sink or a bucket. Put on some plastic gloves. Spray a generous amount of Easy-Off oven cleaner on these parts. (use the low fume variety or you might die). Let the parts sit for 10 minutes. Take a plastic scrub brush and brush the parts while wet with Easy Off. You should see a river of black gunk. Wash and repeat the process until all sticky stuff is gone. At this point you can either re-install the parts or sand them down with very fine grit sandpaper and spray-paint them black.
    If you do not like the result or you want the factory look again you can always just replace the sticky parts with NOS at a riduculously high price. Have fun!
  3. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    lol, I did mine, I have had alotta chit on my hands from workin on stuff over the years but that sticky stuff is near the top for OMG will I ever get this chit off my hands....use gloves, its like roofing tar!
    The oven cleaner works, remember that when you start & it looks like you just did something really wrong!!\
    Good luck,
    Chris
  4. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    The oven cleaner and repaint is good if you are up for the removal of the offending parts to work on them. I was not, so I used Goof Off 2 and Qtips (leaving the console, vents, etc.. in place). Also leaving them in place makes spraying a new finish on not a good idea. ;)
    BT
  5. Ferrari348turbo
    Ferrari348turbo Karting
    Nov 22, 2005
    208
    Florida
    I used laquer thinner on mine, comes off real easy, and comes right off your hands too. After that let it dry and spray a light coat of paint on it. Then I clear coated them for protection.
