Sticky switch cleanup for 360.. This really works... Pretty easily! | Page 2 | FerrariChat
Discussion in '360/430' started by GordonF355, Jul 6, 2015.
  1. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Btw, denatured alcohol is ethanol with stuff added so it's not drinkable. But in a pinch, you probably could use vodka!
  2. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    I have used alcohol on lettering and not had a problem unless like on the door locks the lettering is on TOP of the gooey stuff
  3. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    So the door locks lettering and the air vents white arrows are the only two things you should worry about coming off with the denatured alcohol. Any other button/sticky part which has lettering that will come off with alcohol?
  4. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    Anybody?
  5. Formula1r
    Formula1r Formula Junior
    462
    Los Angeles, CA
    Ross
    Yes. The button for parking lights.
  6. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    How about the buttons on the center console? The images come off, or will they stay?
  7. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    How did the Rust-Oleum textured plastic paint turn out? Besides the steering column, did you use this paint on any other destickied parts such as AC control knobs? I read on another thread that somebody used Rust-Oleum hammered paint for plastic but wonder if there is a comparison between these 2 paints, which one will look better especially on the AC control knobs?
  8. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,956
    MD and NE
    Robbie
    You run a huge risk of removing any lettering, numbers, symbols, etc from your parts when using any type of petroleum distillate, alcohol, thinners, etc.
  9. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    The letter and number decals on the HVAC panel are actually below the sticky goo, so they don't rub off with LIGHT cleaning with the denatured alcohol (I repeated the alcohol cleaning 2-3x but with light pressure until all the goo came off). However these decals will still come off if you apply heavy pressure. Btw, which paint did you use on the knobs after you de-stickied them?
  10. natman316
    natman316 Formula Junior
    Jul 20, 2015
    468
    hey guys, is denatured alcohol the same stuff as the "ethyl alcohol" you can buy at CVS (rubbing alcohol etc)
    Thanks!
  11. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Rubbing alcohol is usually isopropyl alcohol. It has one more carbon in the molecule than ethanol, and is not a straight chain. I don't know if that makes it different enough that it won't work on removal of the rubbery stuff on the switches, but it's easy and cheap enough to find out. One of its common uses is as a solvent, after all.
    Ethanol has 2 carbons, and is the kind of alcohol you find in beverages, so vodka should work. Denatured alcohol is ethanol but a poison has been added to keep people from drinking it.
  12. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,439
    On the Limit
    Dino
    I just had an organic chem PTSD moment! :)
  13. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Take a look at this thread I created to explain to everyone the OEM processes:
    http://www.ferrarichat.com/forum/technical-q-sponsored-algar-ferrari/520454-understanding-ferraris-sticky-interiors-technical-guide.html
    The OEM never used decals - the HVAC panel is laser etched with a clear soft touch over it. You can clean off the clear soft touch but the resulting finish will be a higher gloss as the soft touch lowers the gloss. You also may remove some of the base paint which may damage the laser etched numbers, letters and graphics.
    I hope that explanation helps folks understand the process and potential risks :)
  14. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    Dave, thanks for the great information. It is always nice to learn something new.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    You are very welcome. I feel it's important for folks to understand the process.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    FWIW, I got the black goo on the knee portion of my pants when I accidentally rubbed against the lower cover of the steering wheel housing. I had some rubbing alcohol (isopropyl) around, and it worked well to remove it from the housing. Even if you don't want to attempt or risk damage to the painted or etched numbers, you may want to remove the sticky rubbery stuff from the housing. It does shine a bit more, but under there it doesn't really matter, and it's better than ruining your pants. While I was at it, I took the gooey stuff off from around the ignition key as well, as I was tired of getting it on my fingers every time I started the car.
  17. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Removing the housing, use some 91% isopropyl rubbing alcohol, nail polish remover, or any other product to remove the stickiness and the paint, wet sand the housing, and finally paint it with a flat black enamel paint.
  18. blackbolt22
    blackbolt22 F1 Veteran
    5,801
    Boca Raton, FL
    Mr. Anderson
    My indie mechanic did mine. Charged me $850. I have no patience nor time for a project like this.
  19. 285ferrari
    Sponsor
    Sep 11, 2004
    20,956
    MD and NE
    Robbie
    It is definitely a messy job
  20. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Normally, me too. But there is something mildly therapeutic about rubbing this stuff off, then no longer getting the sticky stuff on your fingers.
  21. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,439
    On the Limit
    Dino
    I just did the trim rings on the vents. Piece of cake and therapeutic.
  22. rongotti
    rongotti Karting
    Apr 11, 2015
    244
    North Florida
    Did it come off your pants? I just got mine yesterday and already have two black smudges on both pair of slacks I wore :-(
    Sent from my SM-N910V using Tapatalk
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Before you ruin any other paints, please give me a call and we can discuss a permanent resolution for your parts :)
  24. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    They were my "work on the car" jeans, so I haven't tried yet. I suggest you dry clean yours, since the material dissolves in alcohol-based solvents.
  25. rongotti
    rongotti Karting
    Apr 11, 2015
    244
    North Florida
    Ah ok, yea I took them both to the dry cleaner yesterday
