Still not right | FerrariChat
Still not right
Discussion in '308/328' started by cessna, Sep 22, 2010.
  1. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    About six weeks ago I was driving my 328 and as I neared my residence it simply stopped, the engine just tuned off, no knock or noises.
    I managed to restart it, but running was really funny and no power or acceleartion. Seemed half of the engine worked too.
    I checked points and distributer caps and found one to be cracked so I changed it. Still car worked extremely bad. My mechanic came and found that no fuel was coming to the heads. Checked fuel pump and was found not to be working. Ordered a new one from Eurospares. Part number was different, but they assured me it's a replacement one ordered from Ferrari.
    Yesterday installed new pump, car started but still no power out of the V8.
    Symptoms: Revs but no power and slow to accelerate.
    Sounds as if working without an airfilter.
    Feeling exhaust, left side exhaust, right side exhaust but warmer temp.
    Valves seem to be a little noiser.
    When starter is turning, fuse box ticks a lot.
    When engine is running all indications seem normal.
    Any ideas.?
  2. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    You may have lost a bank. Try swapping coils and see if it makes a difference
  3. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    #3 Robz328, Sep 22, 2010
    Do you see the SLOW DOWN light on and/or smell rotten eggs with the engine warm? If so, you could have a loss of spark on a bank (try Maurice's idea and switch the coils) and be cooking the cat. This will need fixing prior to any more driving.
    Also, it might be a good idea to check for good spark in of itself (BTW, I haven't researched/inspected any of my coils and distributers (I'll do that soon enough), so here's an ignorant question: could some of the wires/rotors be out of phase?).
    Please also review the fuel system dynamics (Bosch CIS with Lambda (O2) sensor...free pubs are online). There are so many symptoms that overlap with a variety of constrained performance (not necessarily failures either, just poor adjustments, etc).
  4. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Today I should be getting an electrician to check my coils.
    I never smelt any rotten eggs odour.
    Thanks for info.
    Stephen
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Definitely sounds like you lost a bank. Check spark on both banks. Chances are you lost a crank sensor for one bank.
  6. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    328s don't have separate crank sensors (like a QV) for each bank...
    Typically, when a bank is lost on a 328, the problem lays with:
    -Coils (extremely low failure rate part)
    -Ignition modules
    -Coil wires
    David
  7. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,859
    Atlanta
    John!
    And I think the transistors on the coils have been known to go bad as well.
  8. jrinehart
    jrinehart Formula Junior
    Jan 30, 2009
    578
    Chambersburg, PA
    John Rinehart
    I had a similar problem and it was the frequency valve relay, Replaced it and that fixed the problem. My symptoms were rough idling and poor power.
  9. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Yesterday replaced plugs and checked all hightension cables for spark.
    Car still did not start, but found out that new pump is not working when starting car.
    I powered fuel pump directly and it worked. Then checked Bosch relays and they are good too.
    Hopefully mechanic will show up today.
    Any ideas.?
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Stephen, I use to get that smell before and what I found was the my voltage regulator was bad and my battery was being overcharge. The battery acid was boiling until it all evaporated and that's the gas I was smelling. I installed new VG and everything is fine until now.
  11. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    My mechanic came and did some tests. Found out that new pump is getting intermitent power supply, so tomorrow will get an auto elect guy.
  12. Steve Magnusson
    26,846
    #12 Steve Magnusson, Sep 28, 2010
  13. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    I had a very similar problem this year after taking the car out of winter hybernation... only running on 4 cyls... smooth acceleration but no power? Because running on 4 you could also flood a bank and this makes it difficult to start?
    I swapped the coils and played around. it turned out to be a faulty connection in the coil transister! only discovered due to moving the parts around!
    A good chance that it is in that area....
    Hope you resolve your issue as I know how you feel!
  14. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Yesterday bridged the fuel pump relay and pump worked, but still engine won't start.
    All plugs have spark, but rear plugs are soothed black, and foward ones are clean but wet with fuel.
    Incredebile but true.
