still problem - electric | FerrariChat
Discussion in '348/355' started by sdiamond, Jun 10, 2012.
  1. sdiamond
    sdiamond Formula Junior
    Mar 25, 2009
    304
    Kildeer
    Steve
    The alternator checks out fine, volts at battery run at 14.5v, cooling fans kick on and volts at battery drop to 13v andbatterry warning light flickers,not steady but flickers. RH radiator fan does not come on when others do. Replaced realy and fuse, checked fan with seperate battery and it runs without problem. Where else do I look for problem with fan, and if fan is not running why the volt drop and battery light? It's another beautiful weekend and I miss driving
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Check and clean all the ground connections.
  3. F355Bob
    F355Bob Formula 3
    I had a similar problem. The fan blades were free wheeling on the shaft. The motor would run, but the fan blades would not spin so it never felt like the fans ever ran. Replaced the fan.
  4. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    when I connect an external battery the fan does spin correctly. when it's connected through the harness and line back to wherever it goes it does not. The more interestinig question for me is why when it DOESN'T run does it seem to drain the battery? unplugging the fan does not improve the volts to the battery.
  5. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    It sounds like there may be a wire in the fan circuit that may be grounding out somewhere.
  6. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    Todd, any ideas about how to trace it bacK? And is that enough to make the dash light blink and drop the voltage?
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Each fan has it's own fuse #20 & #24 and relays #S & #T. Check those (swap the relays and see if anything changes).
  8. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
    Hang on & back to basics : aren't the 355 fans are separately controlled so they never come on at the same time - in which case that is why only one fires up at first
  9. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    The fuse and relay layout are clear for left and right so both the fuse and relay on right are now new. Yes, it seems true that on the 355 the right fan is a backup but I don't beleive that is true for the 348.. The only other piece I can think of is maybe the temp switch on the radiator itself?
  10. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    The RH fan is triggered by the ECU referencing the coolant temp sensor, which is located just to the right and slightly forward of the oil filter. So this fan would run 'full time' once the engine reaches operating temperature. This fan also draws air through the oil cooler located in front the RH radiator.
    The LH fan is triggered 'mechanically' by the large thermal switch located on the upper 'end tank' of the LH radiator itself. This fan runs 'intermittent' as needed to maintain a steady coolant temperature (about 180°-190° F). This fan also draws air through the A/C condensor located in front of the LH radiator. So in addition to coolant temp the LH fan is also triggered by the needs of the A/C system.
  11. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    He has a 348. Both cooling fans are triggered by one temp switch. The ground for the right fan and the temp switch are in the same spot and the ground for the left fan is in it's own spot which is probably why the left doesn't come on. The left ground is probably suspect. Check to make sure it's good. If you find it's problematic then I would check all the grounds I could find because that might definitely cause undo load on the system. You can check the service manual for these items if you like: 77 is the switch, 80 is the left fan and 82 is the right fan. Also you could have a mild short which might cause the problem.
  12. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    D, you always seem spot on, it's the right (passenger side) fan that is the issue. You said "The ground for the right fan and the temp switch are in the same spot" which is where exactly???
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    On my '95 355, the right hand fan only runs when the oil temp is up around 210. Left hand fan runs intermittently when either coolant temp gets to around 190 or when the a/c is on. Maybe they changed things later on in the 355 run? The right hand fan does not come on very often for me as oil temp usually doesn't get that high.
  14. bosshog8
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    Hmmm...you did say right. I don't know exactly where the ground is. You have to track it down. I'm just going by the schematic in the service manual and it says that ground is shared by the cooling temp switch, oil temp switch, Right hand fan and oil cooling fan. Check the positive on that side for a short also.
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    oops :eek: ........... I guess I though only the 355 has fan issues ........... ;)
    .......... I used to believe the oil temp sensor under the oil tank was what triggered the RH fan .......... but I recently did some research for a friend and I found out the oil temp sensor under the oil tank, is actually a temp sender for the oil temp 'gauge'.
    The give away was that F1 355s did not have an oil temp gauge and also did not have that sender under the tank. So after I did more reading and actual testing on my 1997 ..... I found out the coolant temp sender next to the oil filter was the RH fan trigger and the ECU reference for A/F administration. There is a separate coolant temp sender for the coolant gauge ......... it is located about 6" forward of the coolant temp sender for the ECU. Seeing as how the oil and coolant get warm at about the same time the RH fan turns on, is what caused me to previously think the oil temp was the RH fan trigger ............ :)
    The test I did was to disconnect the coolant sensor (next to the oil filter) and the RH fan did not turn on, even after the coolant temp was at 190° (via gauge) and the LH fan began cycling. Where as before the RH fan would turn on before the LH fan.
  16. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    The wierd part is I know the fan works on it's own, I believe that both sides always worked, the car has never overheated even on the hottest days. So it's not actually even an overheating issue as much as it is the battery drain! I thought disconnecting the coupling at the fan might help keep volts up but nope. I'm no electrical engineer but if the fan is disconnected it has to be "in the wires" instead. Local F dealer service guy said to replace the relays on the LEFT side too and see if that helps. Guess they are interconnected?
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    The temp setting for the RH fan must be at a higher temp because I usually only hear the LH fan cycling on and off. The only time the RH fan comes on is when the oil temp is also high, which makes sense as that's probably when the engine is overall hot enough to trigger the fan. I haven't had any issues with the fans (that I can tell), both fans work, no fuses blown and I've never seen the coolant go over 200 or the oil go over 210 and it was 92 degrees out yesterday. A/C is also nice and cold, which seems to be the exception rather than the rule...
    Hope the op figures out what is going on, sounds to me like a short in the wiring especially if it does it with the fan unplugged.
  18. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    ill try the new fuse and relay on the drivers side, ill try to follow the wires backwards from the rh fan although i'm sure ill lose track, and with sunny days ever present it will be off to the shop for a rather expensive "computer diagnostic". Electrics are quite frustrating, never happens with the Porsche :-(
  19. st4rk
    st4rk Formula Junior
    447
    My Porsche had crazy electric problems once. I traced it back to a bad ground point for the battery and a very worn out ignition switch. After I loosened the screws on the ignition switch it slid right out!
  20. sdiamond
    Mar 25, 2009
    304
    Kildeer
    Steve
    Does anyone have or know where to find a diagram of the routing of wires? The workshop manual has an electrical schematic but that makes absolutely no sense to me. I can see the coupling on the fan and I know which fuse/relay it is in the footwell but in between ???
  21. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    That's the tricky part mate, if you need the wiring diagram and can't read it...............then it's time to take the car to an auto-electrician or learn how to read it yourself. :p
    The wiring diagram tells you all you need to know to diagnose the problem.
    I saw your other thread. If both fans spin freely, then there is probably no high resistance in the fan motors themselves, but there could be resistance in the plug or wiring associated with them.
    **I haven't gone back to read your other thread or this one entirely**
    Your call as to how you want to proceed from here. It's a great learning experience, but if you have no experience reading wiring diagrams then you are going to have to learn or hand the job over to someone else.
    The Ferrari wiring diagrams are not too bad and I bet an experienced auto-elec can read it and probably fix it quite promptly. GOOD auto-elecs are worth their weight in gold. ;)
  22. jaybart
    jaybart Rookie
    Feb 2, 2011
    28
    Los Gatos, CA
    Jay Barthel
    How about with the engine off manually triggering the temp switch 77 by jumping it, then unplug the fan in question and measure the voltage available at the fan connector? You should see 12v there. If you see less or open, your fault is likely in the wiring. Measure the positive lead in the connector against a known good ground, I.e. battery.
    Reading 12v now? Your ground is bad. Trace it back from the connector or run a dedicated lead (if you want a short cut or just temporarily see if that fixes the problem).
    Not reading 12v against battery ground? If the fuse and relay are okay (presuming you checked by e.g. swapping against those from the working side) the problem is in the wire from the relay to the fan. I'd think that's less likely. The parts book does give you a general idea of how that harness is routed. Before getting into tracing that though, I'd run a direct temporary lead from the relay to the fan just to make sure it fixes the problem.
    Let us know what happens.
    Jay.
