Stock Manifolds & Exhaust Brackets
Discussion in '360/430' started by NVH, Mar 13, 2018.
  1. FerrariChat Miami - Earlybird $ ENDS August 24th at 5pm. https://www.ferrarichat.com/forum/threads/ferrarichat-miami-earlybird-ends-august-24th-5pm.582547/ Everything with the event is confirmed and all deposits paid. We already have a double digit number of cars entered including 430 to 488's and 599 to 812's sprinkling in some Californias and classics like 328's. Yes, we have Lamborghinis and McLarens too. We're staying at the Ritz Carlton - Key Biscayne on the beach with events at Homestead Race Track, Miami Design District, The Deck, and Curtiss Mansion.
  1. NVH
    NVH Karting
    72
    Cedarville NJ
    Nowell Herman
    Hi All,
    So here is my question, I would like to keep my car all stock, I currently have 7,700 miles on my 2006 F430 and its all stock at present.
    BUT I am concerned with all that I have read about the stock manifolds and exhaust brackets failing. I will drive my car about 1,500 miles a season and I will not track the car.
    AM I RISKING my cars engine by NOT switch out stock exhaust.
    Thanks for your input!
  2. BlacktopRacing
    BlacktopRacing Formula Junior
    Sep 18, 2016
    415
    Dale
    A Capistro exhaust bracket can certainly help, but I don't believe it will eliminate all risk. There is risk of the manifold self-destructing due to any NVH associated with hard driving period. So, unless you plan to granny the car 100% of those 1500 anual miles, replace the manifold.
    Dale
    whatheheck likes this.
  3. NVH
    NVH Karting
    72
    Cedarville NJ
    Nowell Herman
    So what brands of headers should be looked at
  4. NVH
    NVH Karting
    72
    Cedarville NJ
    Nowell Herman
    I guess it’s time to look into header replacement.
    Can I used stock Ferrari muffler with new headers?
    What brands are out there fabspeed, Capistro and ???
  5. BlacktopRacing
    Sep 18, 2016
    415
    Dale
    I don't often suggest searching the forum, but when I do, it's because of a topic that's been covered to death. So, do a search.
    Also, did you notice how I worked your forum name into my last response? Hopefully, everyone knows what the acronym stands for. :)
    Dale
  6. NVH
    NVH Karting
    72
    Cedarville NJ
    Nowell Herman
    No NVH means? o_O
  7. KBR54
    KBR54 Karting
    Silver Subscribed Owner
    Sep 23, 2017
    111
    Sylvan Lake Alberta Canada
    David Garratt
    NVH and BlacktopRacing like this.
  8. CarAholic
    CarAholic Karting
    May 10, 2016
    205
    I would recommend replacing them just for piece of mind. Even a small chance of a blown motor wasn’t worth it to me. I would go with the top speed headers they are a great product at a vastly lower price then the competition.
    NVH likes this.
  9. mike32
    mike32 Formula 3
    May 13, 2016
    1,409
    Uk
    With the 430 it depends how you drive it, if you have a look under the engine you will see it has a flat panal with 2 small inlets to draw air into the space. My thinking is that if you red line the engine in the low gears you are overheating the manifolds, as you are putting lots of heat in the exhaust but not doing a lot of speed. ie you are not getting enough cooling air over the manifolds, does that overheat the manifold and pre cat ? I think it does not help.
    I fitted the Capristo manifolds with blankets and brackets, the difference of temp in the engine bay is very noticeable. Exhaust expansion of 3/4 inch can be seen on the brackets.
