Stock system, no valves? | FerrariChat
Discussion in '360/430' started by SED, May 22, 2011.
  1. SED
    SED Karting
    Nov 10, 2003
    61
    Stockholm
    Thomas
    #1 SED, May 22, 2011
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #2 FerrariDublin, May 22, 2011
    Exhaust silencer and the tips both look bog standard.
    It's possible someone cut the valves out and welded in some filler pipe along the way but I suspect that it's much more likely that you simply haven't found your valves yet.
    Here's a pic of my standard exhaust removed from the car...... maybe it will help you identify where the valves should be and to determine whether or not they really are there or not?
    Good luck.
  3. SED
    SED Karting
    Nov 10, 2003
    61
    Stockholm
    Thomas
    Thank you! I finally found them, but the hoses were already removed, so I guess it's a aftermarket system for me if I want more sound. Should I do something with the lose hoses (prevent them from sucking in air or something)?
  4. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Good stuff!
    Yes, you should plug the hoses to prevent air from being drawn in the whole time. Some use a golf tee or a suitably sized bolt. Anything at all that's a nice snug fit will do the job.
    Now you need to check out exhaust options, there's a current thread you should check out as it will probably develop over coming days.........
    http://www.ferrarichat.com/forum/showthread.php?t=324610
    Good luck!
