Stooge style butterfly valve syncronisation | FerrariChat
Discussion in '348/355' started by Cauf61, May 1, 2018.
  1. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    StuR likes this.
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    Use a more viscous liquid or it will be shaking around too much, maybe maple syrup :)
    I have an old 12 cyl unit I use
  3. WATSON
    23,832
    WI
    That's pretty cool.
    Can someone better explain how to use that?
  4. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Very simple.
    You connect each bottle suction tube to an engine inlet side.
    The vacuum in each bank will pull on the liquid and thus you can calibrate/balance both sides to equal vacuum = equal liquid level as both bottles are connected via a tube ( communicating vessels )
  5. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Received my tube pillars today. In the next day's going to test the synchronisation.
    If there is an unbalance, should it be adjusted by the linkage screw ( you see on the right side) or the both the air screws ?
    For the moment my idle is very good so i don't expect any issues.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    Make sure the plenum butterfly is closed / sealed between the 2 banks or it will mess up your readings
  7. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Patrick, where did you find the metric brass fittings? Probably won’t help those of us in the States, but who knows.
    Let us know how the balancing goes.
  8. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  9. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Can somebody tell me how to disable the plenum butterfly valve ( not the air valves ).
  10. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    As far as i found out the linkage screw serves more for the mechanical throttle valve synchronisation and the air screws for the air volume synchronisation.
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Thanks for the fitting source.
    You don’t need to disable the valve between the plenums— it doesn’t actuate until way up in the rev range. But I think the 90 degree fitting on the rear of the left plenum provides vacuum to it and the air injection system so you could just plug that fitting.
    I think what Tim was suggesting is to ensure that the valve itself is sealing correctly so that there is no leakage between the two plenums when the valve is closed. Hopefully he’ll weigh in with more.
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    Correct, just make sure they are sealed well
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    Forgot to mention
    Clog those air breather to the headers when you tune it. I eliminated them on mine they do nothing but cause vacuum leaks
  14. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Tested my stooge syncro tool today. Complete failure !!:confused:
    It seems the engine draws a lot more vacuum then a motorcycle.
    The bottles where squashed in a few seconds.
    The engine has burned some wiper liquid to ( lol ) but no problem.
    Back to the drawing board i think.
    Good point : the fittings work fine and my 3D printed tube blockers also. Always end on a good note.;)
    Grts
    Patrick
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,796
    Lake Villa IL
    Not a complete failure, it was just a top end cleaner instead of a balance tool :D
    Cauf61 likes this.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    Tim Dee
    LOL do you remember in the 80s we used wiper fluid for water injection
    Pangea and Cauf61 like this.
