Stop and Go Traffic with Carb Car | Page 2 | FerrariChat
Discussion in '308/328' started by cbmcdona, Mar 5, 2025.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,257
    Snohomish, WA
    Eric L
    I'm the owner of the car and pump in that photo. That was 15 years ago and the pump is still working great. As I recall, the trickiest part of the install was fuel line routing. It is mounted using the original pump mounting location with the pump outlet to the bottom. I really don't think it matters how it's oriented. If you want more details, I can get under there and take some more photos
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,944
    Atlanta
    John!
    Hidden in the trunk well on the carpet just behind the left rear wheel, no one will never see them. Running a Pertronix coil on the otherwise stock system will not change anything.
  3. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    So I swapped in the Pierburg pump this weekend and opened up the return line. In short the car drives much worse. It will run ok for a short time at low revs and low load. But if you try to accelerate the car sputters and acts like it has run out of gas. It seems the Pierburg pump isn’t supplying sufficient pressure with the return open. I checked flow out of the return and the flow is really good. I’m wondering if the return flow is too much and now I don’t have enough pressure to fill the float bowls. With the Hardi pump and return blocked, the car ran terrific except stop and go in car pool. Now it can’t even make it two miles down the road without sputtering and shutting off. I had bought the car as a non runner. At the time it had the original Corona pump and the return line was blocked. Thoughts?
  4. Steve Magnusson
    26,946
    #29 Steve Magnusson, Mar 23, 2025
    Measure the fuel pressure up at the carb inlet? You've got the safety relief valve plumbing as stock? Have you confirmed that the orifice opening in the 7/8 carb fitting with the return hose is the specified size (1.8mm IIRC)?
    cbmcdona likes this.
  5. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    No safety relief plumbing. All of it was gone when I got the car. Mine goes from the tank -> filter -> Pierburg pump -> carbs -> return to other tank. Do you think I need to find a way to built the safety relief. I tried measuring the pressure down at the pump and with the return open it’s only 2 PSI. I’m thinking the outlet on my last carb that goes to the return line might be too big. 2 PSI at the pump seems low. Lots of flow out of the return line but very little pressure.
  6. Steve Magnusson
    26,946
    No, you'll be no more unsafe than a euro version carb 308 (and it can't be plumbed wrong, nor fail, if you don't have one ;)).
    I would verify the size of the return orifice.
  7. Steve Magnusson
    26,946
    One other thought -- have you ever measured the voltage at the fuel pump when the engine is running? I can see how a lowish voltage there could fool someone into thinking that blocking the return was the "fix".
  8. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    That’s good to know. I’ll leave that part alone then. I checked the orifice just now. Couldn’t get my caliper in there with the airbox on but the orifice looks big. By eye, it’s at least half the diameter of the inside diameter of the line. So probably 4-5 mm or so. How small should this orifice be? 1-2mm? I also noticed that if I take the line off the pump itself, the flow at the open pump seems nearly the same as flow out of the return line so it seems the orifice is not restricting the flow. There is also no change in tone when turning the key on after the floats fill. The pump doesn’t slow down or change tone as if it’s working harder or under pressure. I’m guessing I need to restrict the return flow. As I don’t have a different orifice, I found an in line restrictor from Riva racing. It allows different carb jets to be screwed into it to change the orifice size. Do you think this might work with a 100 pilot jet screwed into it? That would give me a 1mn orifice for the return. I could also use a 150 if you think more flow is a better idea.
  9. Steve Magnusson
    26,946
    #34 Steve Magnusson, Mar 23, 2025
    I believe it should be a 1.8mm ID -- Ferrari PN 108032:
    https://www.ferrariparts.co.uk/part/ferrari/108032?id=52171
    (Although the earlier 308GT4 WSM page C13 has the "Calibrated hole for fuel relief" as 1.5 mm. It should definitely not be 4-5 mm ID.)
  10. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    This helps. So I’m guessing the restrictor from Riva with a 150 pilot jet in it should be ok then. It would give me the 1.5mm orifice the GT4 specifies. I’ll keep you posted once the restrictor arrives. The joys of buying old cars and not knowing what was done to them in the past.
  11. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Quick question. Would you recommend adding a fuel pressure regulator between the Pierburg pump and the carbs as well or would having a properly sized orifice most likely solve the issue? I know Webers are pretty sensitive to pressure. I was looking at getting the one from Holley that has a range of 1-4 PSI and is preset at 2.7. Or is this just unneeded complexity in the system?
  12. Steve Magnusson
    26,946
    I'd vote "unneeded" as the Pierburg pressure spec is so close to the 308GT4 WSM spec.
  13. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Thanks! That’s what I was thinking. I’ll go without the regulator and just to the 1.5mm orifice. I’ll keep everyone posted how it goes!
  14. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Well this is frustrating. I put the restrictor in the line today with a 140 pilot jet and it is equally as bad as without the restrictor. I investigated if it was a venting issue by putting a vented gas cap on it which did not help. In every instance the car would die at anything over 3k rpm under load. Light load or low rpm it was fine so it seems there is not enough fuel to keep it going when the return was blocked with the Hardi pump it was at least happy besides the car pool. Now it won’t even go a few blocks down the road with the return in place. It is extremely frustrating.
  15. Steve Magnusson
    26,946
    Have you confirmed what the voltage is at the fuel pump when the engine is running?
  16. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Pump voltage seems ok. It stays over 13V and never stops running. I may pull the fuel filter temporarily and see what that does. It’s a brand new filter but maybe it’s causing a restriction. I’m not sure if the Hardi does better with the restriction of the filter before it than the Pierburg. I’ll see what it does without the filter and if it’s better I may replace it even though it has less than 100 miles on it. I’m losing my mind I think lol
  17. Steve Magnusson
    26,946
    #42 Steve Magnusson, Mar 29, 2025
    It shouldn't be this hard. The stock carb 308 fuel system (with return) is working fine on most carb 308 ;).
    You can also do a fuel delivery test to confirm/deny if you have an obstruction in the fuel filter or elsewhere: If you remove the fuel line feeding the carburetors and put it into an appropriate container, you should get about 1 cup (or more) of fuel out in about 9 seconds when running the fuel pump manually if the pump is delivering the 100 liter per hour specification.
  18. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    I agree. This should be one of the simplest fuel systems ever. I’m not so sure why it is giving me such a headache. The only other thing I can think of is a mounted the pump horizontally instead of vertically. It seemed to fit better this way and kept the lines tucked up a bit better. However I’m not sure if it performs better in a vertical orientation. That is the only thing different from the install picture you posted as far as I can tell besides the safety bypass being gone on mine.
  19. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Ok I just read something else interesting. The Pierburg installation instructions say the paper fuel filter must be installed after the fuel pump with only the fine mesh filter before. The standard routing on the 308 puts the paper filter before the pump which is what I did. I wonder if the pump is running into issues getting fed on the suction side under high demand?
  20. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,913
    Mike 996
    If the fuel pump output pressure/volume is within spec, I don't see how this can be a fuel pump problem. Per the description it sounds more like a carb float level issue to me.
  21. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Carb floats should be fine. Rebuilt carbs with floats all adjusted to within spec. With the Hardi pump installed and no return the car was absolutely fine under load and could run to 7k no problem. The only issue it had then was in the car pool line. Now with the return open I never can seemingly get enough fuel. Even with a restrictor in place I’m only at 2.5 psi at the pump. I would think it should be at closer to 5. The Pierburg instructions say not to put the filter before the pump. So I have a feeling the filter is being a restriction for some reason. I’ll try to swap it this weekend and at least see what it does. Worst case is I put the Hardi back and deal with the slight issue during car pool as the car ran amazing that way otherwise
  22. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,913
    Mike 996
    Of course it could simply be a carb(s) idle fuel/air mixture is excessively rich OR a float needle not seating properly even though the float level is at spec. Needle not seating/float level too high often adversely affects idle/low speed but goes away as the load increases
    Hope you are able to quickly sort it out!!
  23. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,257
    Snohomish, WA
    Eric L
    Do let us know how you make out with this. My pump is installed before the filter. So fuel is gravity fed from the tank to the pump then to the filter. Pretty sure that's how my original pump was plumbed.
  24. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    This is really helpful information indeed! I’m betting this is my main issue. I’m hoping to swap the lines around this weekend. I will let everyone know how it goes.
  25. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    Thanks! When I was running the Hardi pump my plugs all looked a nice light brown across all 8. It only had issues in stop and go idling. The major issues arose with the Pierburg pump. I guess first step is to change the lines around and if that doesn’t do it, dive back into the carbs.
