Stop my drip....help please.... | FerrariChat
Discussion in 'Technical Q&A' started by lotusk, Jan 27, 2016.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    I have a very small drip coming from the end of a silicone water hose on my 355....it's the hose that connects from the engine to the underside of the expansion tank....the drip is at the expansion tank connection...
    It is a brand new Scuderia Rampante very high quality silicone hose and clamp.
    The drip is very slight but after a run the next day i can see a few drops have escaped and dropped onto the throttle quadrant.
    I have the clip about 1/2 inch from the end of the hose and tightened it down with a socket tight...the hose is slightly bulging just after where the clamp is situated...i did this whilst the engine was warm....this reduced the amount of leakage but i am still seeing a few drops...
    Any tips to share that would stop the drip?
    I'm sure the pipe and its nipple are in good condition.
    Shall I go in and tighten the clamp some more?..... Scared of deforming the pipe or should I not worry?
  2. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    Be very careful on how tight you make the clamp. The hose nipple can crimp and then it's deformed and will never stop leaking.
    If you get really interested in looking at it. Pull the hose and inspect the hose end and nipple for scratches or cracks. It could be a simple defect in the nipple when produced, but would then require a repair or new expansion tank. If all looks good, get some high temp silicone sealant and put a little on the nipple and clamp up the hose. Let it cure for 24 hrs and fill with fluid. That's kind of a redneck way of stopping the leak, but it's worked for me on an old Ford.
  3. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    I would send a PM to Dave Helms @ Scuderia Rampante. I'm quite sure he has some guidance at hand for you.
    Cheers,
    Hank
  4. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    thats a good idea
  6. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,654
    Palo Alto,CA,USA
    Walt Kimball
    Silicone hoses don't compress like stock hoses. I use two clamps everywhere.
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Interesting
  8. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Old school, but on the race cars we use a seler as well as 2 clamps for Endurance cars.
    On street cars, I still tend to use a little aviation gasket sealer around the tube, helps seal.
  9. Redneck Slim
    Mar 10, 2011
    1,654
    Palo Alto,CA,USA
    Walt Kimball
    I have wondered about doing this. What happens when you remove a hose? How do you remove the sealer from the inside of the hose and the outside of the tube without damaging either?
  10. Mr. V
    Mr. V Formula 3
    Oct 23, 2004
    1,247
    Portland, Oregon
    What brand of sealer?
    Would good old RTV work?
  11. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    If I may comment, and a bit off topics there are two types of curing agent in RTV one is citric acid. The other smells like tooth paste and is non corrosive.
    Reading this I would say the clamp is resting on the nipple of the tube, as has been suggested try repositioning the clamp more towards the end of the hose.
  12. Carlo_C
    Carlo_C Rookie
    Mar 12, 2015
    11
    +1
  13. Hocakes
    Hocakes Formula Junior
    Apr 24, 2010
    491
    FL
    Pretty sure you mean acetic acid. Hence the vinegar smell.
  14. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Make sure you also look carefully at the exterior surfaces of the nipple (spout) on the tank. It does not take too much of a scratch, dent, distortion, or spot of corrosion to interfere with the hose's ability to make a good seal.
  15. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Ok
    Will do
  16. DesertDawg
    DesertDawg Nine Time F1 World Champ
    93,277
    The Desert
    DesertDawg
    A dose of penicillin usually does the trick.
    Oh, wait...
    :D:D:D
  17. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    That Permatex Aviation sealant has been used successfully for many years and it works great to fill minor imperfections on a nipple, however I have no experience with using it on silicone hoses. I have not had the best of luck with silicone hoses; especially small ones; the big ones on coolant hoses-- no problem, but my preference is neoprene for the small diameter hoses.
