Storage question | FerrariChat
Storage question
Discussion in '360/430' started by SAVANTAUTO, Dec 24, 2014.
  1. SAVANTAUTO
    SAVANTAUTO Karting
    Nov 5, 2010
    178
    Was wondering if any of you guys disconnect the battery rather than keep it on a tender for long term storage. Other than the radio code needing to be re entered, is there anything that could harm the car? I assume not as Ferrari indicates in the manual to use the master disconnect switch in the trunk.
    Any thoughts?
  2. slayerofsouls
    slayerofsouls Formula Junior
    Jul 8, 2014
    265
    Somewhere
    I keep it on a tender for long term storage. I dont see the point of disconnecting the battery or turning off the switch.
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    same for me.
  4. bball16
    bball16 F1 Rookie
    4,127
    NY LI FtL
    Tender always...
  5. tyke
    tyke Rookie
    Oct 23, 2009
    17
    England
    Paul Crossley
    I have done both. The car was fine after reconnecting the battery. The dealer reckoned I should let the car idle for 20/30 mins after first starting it to let the engine management adapt at idle. I did do this but not sure that was required
  6. SAVANTAUTO
    SAVANTAUTO Karting
    Nov 5, 2010
    178
    Thanks. The reason I was asking is because I don't have access to electricity in the area where the car will be stored for the winter.
  7. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    +1
  8. SAVANTAUTO
    SAVANTAUTO Karting
    Nov 5, 2010
    178
    Thanks to all. As far as a battery tender goes, do any of you have a particular brand you prefer? I have used the battery tender brand in the past and it worked fine. Just not sure with an f car. I am getting very close to pulling the trigger on my first f car so I want to get housekeeping in order.
  9. howl
    howl Formula Junior
    Apr 10, 2011
    505
    Chicago/Boca
    Tom
  10. SAVANTAUTO
    SAVANTAUTO Karting
    Nov 5, 2010
    178
