Storage | FerrariChat
Storage
Discussion in 'Detailing & Showroom' started by 8202632, Apr 1, 2018.
  1. 8202632
    8202632 Karting
    Jul 9, 2017
    167
    Memphis, TN
    CDC
    hey yall. Just checking to see what yall do with your cars. I have 4 cars and 3 garages and I'm not going to let any new to me vehicle sit outside.
    What solution have you come up with? I could:
    Build more garage space (my ultimate solution_)
    Rent an enclosed storage unit at the local ministorage
    Get rid of a one car (last solution)
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    Lifts ?
    Sent from my Moto G (4) using Tapatalk
  3. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Yep, like flash said. If you have a high enough ceiling stack them. I got this 4 post lift for around $2k delivered. It’s lighter duty but plenty for lifting Ferrari.
    RedNeck and billy.gif like this.
  4. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    just get a 4 post lift like 97 spider said
  5. BlacktopRacing
    BlacktopRacing Formula 3
    1,002
    Pittsburgh
    Dale
    Just curious, what is the minimum ceiling height needed for a 4 post lift solution?
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    Add height of both cars and add safety 12 in or more
  7. BlacktopRacing
    1,002
    Pittsburgh
    Dale
    Bummer, my garage ceiling is only 9' (and only 8' when the doors are open.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    9 ft usually works for most of f cars ..but you will need a high lift garage door coversion with shaft door opener
  9. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    590
    SW Suburbs of Chicago, IL
    Lawrence P.
    I have a large support beam running through my garage so afraid of installing a lift (don't trust that I would not hit the beam). I found a good storage facility to store my least used car (and trailer). For $60 per month, it is reasonable option to keep three toys.
  10. FiveLiterEater96
    FiveLiterEater96 Formula 3
    Nov 5, 2005
    1,858
    Illinois
    Andrew
    Whats the story with that 360?!
    steved033 likes this.
  11. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I’ve been dismantling exotics on the side for sometime now. That’s one of the 5 360s I’ve done so far. I’m just gearing up to go at it full time and have 3 360 spiders on the way to me right now for dismantling. So if you need anything you know who to call. I usually sell parts at half what you see them on eBay for and way less than the big dismantlers.
  12. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    I recently downsized from a 3 1/2 car garage to a one car garage on my current home.
    I have a Jag, my Ferrari and and a Ford F150 as my DD.
    I rented a 10x20 storage unit owned by a local garage that services classic cars, mounted a Schumacher solar battery maintainer on the roof, with the help of the owner. I swap the Jag and Ferrari out, depending on which car I want to play with at the current time.
    Cost in my area is $89 per month for the 10x20.
    The only downside is the limits of the solar mainaterer: went to start the Ferrari after 4 months storage, battery disconnect off during storage and she only showed 4.0 volts. Probably need to put a new battery in the Ferrari and jump starting was a pain, getting to the positive terminal on the Ferrari was a ******, so now the Ferrari resides at home, hooked up to a CTEK al all times and the Jag is in storage with the battery disconnected and the Schumacher solar hooked up to the battery alone.
    A lift is nice, and i have one, but it is a MaxJax and only goes up 48" or so, ok for working on the car from a seated dolly, portable and removable, if you need the space, but not good for storage. Also, think about "drips" from the upper car getting on to the lower car if you go the lift route. Drip trays are available. Italian stored over British, French over Italian, your call, your cars, lol.
    W'ell see how this works out.
    Alden
  13. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    9' should work for most sports cars, but SUV and a car will not. I have 9'-4" and easily does 2 ferrari/lotus/etc.
    If you are super tight on height you need to check the heights of the locks/stop blocks as you need a few inches to go up and release so you can go back down
  14. LBBP
    LBBP Formula Junior
    Another option in the car lift vein is the Autostacker, it has the versatility of a storage lift and yet has removable center panels for maintenance.
    https://www.autostacker.com
  15. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Alden, that's an excellent value for that size of space! I started renting the same size in west Orlando, for $129 per month.
  16. ridege55
    ridege55 Formula 3
    1,385
    Manhattan Beach, CA
    I have two 10x20 units in SoCal for each Ferrari. $277 for each unit but I was notified that the units will be increasing to $325 per month.
  17. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    I should count my blessings that I'm not in SoCal!
  18. shawdut
    shawdut Formula Junior
    May 30, 2014
    783
    SoCal
    Shawn D
    I’m looking for something similar - what area are yours?
  19. ridege55
    ridege55 Formula 3
    1,385
    Manhattan Beach, CA
    It's at a US Storage in Gardena. Awesome place, management lives on site and each unit has electrical so I can plug in a tender.
  20. shawdut
    May 30, 2014
    783
    SoCal
    Shawn D
    Thanks for the info - a bit far but I’ll check it out
