storing a car for 3 to 5 years... | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by ttforcefed, Nov 27, 2018.
  1. ttforcefed
    ttforcefed F1 World Champ
    19,266
    in a climate controlled facility. Wld you drain the oil? wont be able to change it.
  2. LandandcarsAZ
    LandandcarsAZ Karting
    Jun 14, 2018
    180
    Scottsdale AZ
    Robert
    No access to the facility?
  3. ttforcefed
    19,266
    Nope keys are coming with me
  4. LandandcarsAZ
    Jun 14, 2018
    180
    Scottsdale AZ
    Robert
    Drain oil and gas if possible. Lower tire pressures and cover the interior and exhaust pipes so no animals decided to make it a home.
  5. ttforcefed
    19,266
    Looking at using vp fuel or will drain.
    Its more the oil that I’m torn on. Shelf life of oil and filter is 5 to 10 yrs so Wldnt the metals be better off having the oil present? Stored in climate control with no temp fluctuation and no humidity is a pretty tame environment for the oil to hold up in.
    Caeruleus11 and I'm 360 Canuck like this.
  6. LandandcarsAZ
    Jun 14, 2018
    180
    Scottsdale AZ
    Robert
    I’d say drain. My 2 cents.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,038
    Central NJ
    Dominick
    #7 flash32, Nov 27, 2018
    Before we make any kind of recommendations ....How many miles on oil ..were all trips prior mostly short trips or did car come up to full oil temp ?
    Although sounds long .. 3 years is not that big a deal in a climate controlled environment
    Tires , battery, bugs, and mositure is your biggest concern
    Tires should be put on thick foam and slightly over inflated to avoid flat spots.. even if you get them they will eventually work themselves out
    Battery on a good charger will most likely make it 3 years but not sure about 5 especially if it already has miles on it
    If on concrete .. put something down to avoid mositure from rising to underbody of car unless you have a exopy covering
    Oil ( based on Blackstone analysis) does not get old just sitting
    The reason I asked above if the oil is already contaminated it may change my suggestion
    If oil is fairly low mileage and always was brought up to temp when driven .. just leave it in ..
    And even if old .. by draining it you won't remove it from bearing .. they will hold the oil(designed that way) so not much benefit ..
    If you can drain it .. why not just out fresh oil in an start it up and run it before storing
    Sent from my moto x4 using Tapatalk
    I'm 360 Canuck likes this.
  8. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Why would you drain oil?
    308 milano likes this.
  9. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I'm thinking some people think that used/contaminated oil would have acids in it which would/could corrode the inside of the engine, pan, crank or whatever. Most of the oil would be in the sump so that would be the area most effected and perhaps the crank. There would still be some oil/film in contact with other engine parts so its impossible to really get all the oil out so IMO not sure why one would do it either. As for gas I can tell people for a fact I have had 5+ year old gas treated with stabil in cars and zero issues upon pulling it out of storage.
    Davesvt2000 likes this.
  10. Cotton
    Cotton Formula Junior
    Dec 11, 2008
    413
    TN
    I’ve never drained the oil when storing for that length of time. Don’t know anyone else who does either. I would drain the gas unless it’s treated.
  11. 1Superleggera
    1Superleggera Formula 3
    1,772
    North East
    Scott
  12. ttforcefed
    19,266
    - the car has been serviced annually and will have fresh oil before it goes into storage.
    - going to fill the tank with VP
    - i change tires every 5 years no matter what so that's fine.
    - i agree draining oil doesn't make sense - once i left synthetic oil in a piece of tupperware out for 4 years in my garage and it didnt degrade at all.
    Caeruleus11 and Davesvt2000 like this.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,038
    Central NJ
    Dominick
    I think you will be fine .. I assuming you are taking battery out as well ?
    I have another post in tech q/a about the question that comes up after the storage .. what to do to get it going .. maybe we can some thoughts on that
    The question of what to do once you come out of storage always comes up at local meets because many do not intent to not use cars for a long time and then "boom" 3 , 4 years have pasted and not sure how to get it started without damaging anything
    Some say just start it ... to pull plugs and put oil in cylinders and rotate engine
    SO far thread has gotten little response
  14. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    762
    Vermont
    john truskowski
    Definitely remove battery, careful with the vp fuel if your car has cats. Ethanol free fuel with stabil, but after 5 yrs wont be very good, so fill with fresh fuel after storage. I wouldn't drain oil, but crank engine over with fuel pump fuse removed for a minute to get oil back into the lifters and bearings before running again.
  15. ttforcefed
    19,266
    what is the point about ethanol free and cats?
  16. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    change oil -- use oil high in acid neutralizers.
    lift suspension so tires do not touch the ground
    empty gas tank
    drain coolant
    remove battery
    cover car
    Coming out of long term storage:
    inflate tires
    install new battery
    fill gas tank
    add coolant
    flush brake fluid
    feed the leather
    <optional>
    remove spark plugs and inject 1cc of oil into each cylinder
    Key car on and wait 60 seconds before attempting to start car.
    <optional>
    remove fuse to gas pumps
    turn engine over until oil pressure gauge reads 30 PSI
    install spark plugs
    install gas pump fuse
    attempt start car.
    Makuono likes this.
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,038
    Central NJ
    Dominick
    Considering our linings are not cast iron would there ever need a prelube in cylinders ?
  18. henryr
    henryr Two Time F1 World Champ
    22,467
    Atlanta
    Juan Sánchez Villa-L
    1) where you going and can i come with ?
    2) fresh fluids, ethanol free gas with stabilizer FULL TANK
    3) preferable to leave car on a trickle charger
    4) i prefer to have the weight of the car on blocks (tires touching okay) inflate a bit higher
    5) i prefer to stuff a micro filter rag in the exhaust pipe
    6) a BIG money roller like you should really spring for a CARCOON
  19. DrewH
    DrewH F1 World Champ
    19,401
    Vancouver, BC Canada
    Andrew
    Here is my short list:
    1) Car on jack stands so the tires and suspension are suspended.
    2) Drain all fluids.
    3) Take battery out and do something else with it.
    4) As others have mentioned be aware of potential rodent issues.
  20. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    I agree.
    Also protect it with a cover and put a desiccant everywhere. Mothballs smell but keep out nasties.
    Matt
    DrewH likes this.
  21. tritone
    tritone F1 Veteran
    7,214
    On the Rock
    James
    A. Full tank of non-ethanol gas + stabilizer
    B. Drain/empty tank/block filler
    Sort of equal responses.......discuss?
    (... have horror story of 1/2 tank ethanol for 2 yrs = 5 figure repair bill.....lets not go there....:()
  22. jjtjr
    Aug 29, 2016
    762
    Vermont
    john truskowski
    The point is not about ethanol free and cats, its about Racing fuel (VP) which can be leaded and cats. They do not mix.
    I never put any ethanol fuel in my car, it is made to be pumped into your car and burned immediately. Any long term storage turns it into a green mess the ends up contaminating the entire fuel system. :mad:
  23. ttforcefed
    19,266
    Vp makes fuel specifically for long term storage, in addition to their racing fuels
  24. ttforcefed
    19,266
    here is the summary from my 93 cobra which sat for about 4 years in between oil changes:
    "After less than 150 miles, most of the metal is likely just carryover from the previous fill. Still, lead stands out next to averages (based on oil run ~3,500 miles). We're not convinced it shows a problem, though. Lead can come from the bearings, but it could also be from octane boosters or leaded/track fuel, if you've used anything like that recently. Monitor for engine knocking just in case it is bearing wear. The viscosity read in the 5W/20 range, insolubles are good, and the TBN is strong at 7.7. Check back on lead in 500-1,000 miles."
    Caeruleus11 likes this.
  25. ttforcefed
    19,266
    Response from blackstone about oil decaying while just sitting:
    “The oil won't go bad on you just sitting in the engine, and it only accumulates metal with use, so keeping it in the crank for years at a time is fine to do. And that goes for all oils, not just synthetic ones. We've yet to find any one oil that out performs another, so you can expect similar results (at least as far as wear metals go) with whichever brand you choose to use.”
