Stradale 4 point racing belt retrofit? | FerrariChat
Discussion in '360/430' started by andybm3, Aug 17, 2004.
  1. andybm3
    andybm3 Karting
    237
    Andy
    The US Stradales' come with standard seat belts and I am contemplating retrofiting the 4 point racing belts to the car. Has anyone done this? is it possible?
  2. ChalStrad
    ChalStrad Formula 3
    Jan 22, 2004
    2,249
    Lausanne Switzerland
    Peter Mann
    It must certainly be possible - however, you need to watch out for the following:
    The "anchor" points of the harness need to be located where the rear bulk head is strong enough so that in the unfortunate event of a shock the "anchors" do not give way, or you may need to add a support member to ensure a great enough strength
    Harnesses are illegal in the US, so the accessibility of the "anchor" points that are used on euro spec cars is apparently quite different,
    US cars have a child seat support mechanism with an airbag de-activator which euro -spec cars do not have, so watch out for not affecting those sensors,
    keep the original set up for the day you sell the car
    Good luck
  3. Izza
    Izza Formula 3
    Nov 3, 2003
    1,046
    London
    On this point, I took out the airbag fuse on my Euro spec spider to fit my son's baby seat in once and it wouldn't select sport mode. Corrected as soon as I returned the fuse so trial and error on this issue takes only a few minutes.
  4. thomas_b
    thomas_b Formula Junior
    Sep 15, 2003
    765
    the US Stradale does not have the mounting point for the harness - you would have to get the left side welded in - needs to be done in a special shop
    search for rollbar & stradale and you find several discussions including why some believe it is not a good idea to add a harness without rollbar
  5. watt
    watt Formula 3
    Jun 17, 2004
    2,265
    Northern Rocky Mountains
    Giuseppe T Hemingway
    peter,
    i am confused -- my manual does not indicate a airbag de-activator, but i could sure use it as i have a 10 year old riding daily, and have always turned off the airbag in my gt2's and 3's.
    How does one turn off the passenger airbag in a US CS? [if this should be a new thread, please tell me]. thanks
  6. ChalStrad
    ChalStrad Formula 3
    Jan 22, 2004
    2,249
    Peter Mann
    Giuseppe
    I actually have a Euro spec CS which i keep in Europe, but it is my understanding that when you put the child seat in the US spec CS you feed the strap through the hole in the middle of the seat back and clip it into a special bracket that is mounted on the fire wall. When you clip into the bracket it automatically de-activates the passenger airbag.
    This, of course, confirms that there are sensors located there and may be an issue if welding in the support brace for a harness.
    Also, must agree with Thomas B: If you are going to go to the trouble of putting a race harness it is because you are going to track the car a lot and in that case you really want the roll bar too - which is also illegal in the US....
  7. watt
    watt Formula 3
    Jun 17, 2004
    2,265
    i just spoke with Eric, our FNA man: there is NO airbag cutoff in USA CS's
  8. udalmia
    udalmia Guest
    so if someone wants to put a 4 point harness in what modifications have to be made to the car?
  9. bayareaferrari
    bayareaferrari Formula Junior
    Dec 19, 2004
    672
    California
    Any insight on how this is accomplished?
  10. Ricambi America
    Sponsor Owner
