Stradale Exhaust Valve | FerrariChat
Discussion in '360/430' started by kchendds, Feb 10, 2006.
  1. kchendds
    kchendds Rookie
    Apr 13, 2005
    31
    Yorba Linda, CA
    Kalvin Chen
    I have been told that the exhaust valve on the Stradale exhaust can be unplugged to bypass at the entire rpm range.
    Has any of the CS owner done this before. Any instructions?
    THANKS
  2. motion
    motion Formula Junior
    May 4, 2005
    584
    At the track
    Motion
    I'm sure most Stradale owners have done it at one point. I unplugged mine for awhile. At first, I liked the louder growl, but then after awhile it got to be a bit too much. Its more of a low-pitch growl, rather than a high-pitched Capristo scream.
  3. DJ4200GT
    DJ4200GT Formula Junior
    Aug 18, 2004
    354
    I second that instructions would be great =)
  4. lrattner
    lrattner Formula Junior
    Sep 15, 2004
    390
    Delray Beach, Fl
    Dr. Lonnie Rattner
    It's really very simple. All you do is pull the vacuum hoses from the line coming out of the valves. These valves are in plain sight. When you open the rear hatch, they are located on the right and left sides on the exhaust line. After you take the vacuum line out (again just twist it easy left to right and walk it off the valve line) plug the vacuum line with a screw (6-7mm) so no dirt gets sucked up into the line. Then secure the line either with a tie or place the line between other hoses to secure it.
    Total time is less than 5minutes-the resulting sound is great. If you get tired of it, it is easy to just replace the line back into the valves,
  5. mahwon
    mahwon Formula Junior
    Dec 1, 2005
    489
    NYC-Shanghai
    Done it.
    i did that while i was having hyperflo cat installed.
    so it went from stock, to hyperflo cat with valve permanantly open.
    but i still could not tell significant change in sound. on low rpm range it still sounds mellow like stock, over 5500rom on WOT it screams but thats what the car did in stock form anyway.
    so, i got a capristo level 3. thats the BEST MONEY i ever spent modifying a ferrari.
  6. lrattner
    Sep 15, 2004
    390
    Delray Beach, Fl
    Dr. Lonnie Rattner
    All I can tell you is that it made an enormous change in the sound on my car. It really howls now from low rpm to an absolute roar at high rpm (over 6,000).
