News
Stradale Race Harness
Discussion in '360/430' started by cantwait, Feb 14, 2008.
  1. cantwait
    cantwait Rookie
    Sep 12, 2006
    46
    quick question, I am looking at a CS with lap belts, no roll cage. Is there any way you could fit a race harness for track days and then easily remove or can they only be attached to a roll cage? Thanks
  3. Ricambi America
    Sponsor Owner
  4. djimenez
    djimenez Karting
    Nov 30, 2005
    181
    Monterrey, Mexico
    David Jimenez
    Daniel,
    can someone have both? or do I have to remove/replace my old 3 point when I install a 4 point?
    If I were to buy a set, would you provide me with all prts needed? that is grommets, bolts, etc..
    david
  5. cantwait
    cantwait Rookie
    Sep 12, 2006
    46
  6. Ricambi America
    Sponsor Owner
    See attached pictures for mounting design. I don't think you could have both simultaneously, as I *think* the lower mounting points on the 4-point harness go into the same locations as your 3-point belt + tongue. The upper mounts section attaches most suitably on the parcel shelf. These are not legal for use in the US on a public road or highway. For track use only. Yadda Yadda Yadda.
    http://www.ricambiamerica.com/product_info.php?products_id=261371
    http://www.ricambiamerica.com/product_info.php?products_id=261370
  8. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    However you might want to search else where this has been discussed at some length before.
    http://ferrarichat.com/forum/showthread.php?t=113040&highlight=roll+cage
    Lots of people will advise you not to get belts without a roll bar. In the event that the car is rolled over, the roof is crushed, you cannot move due to the belts.
    Depends on which risks you are worried about. The advantage is of course you can wear a hans.
  9. PCH
    PCH F1 Rookie
    Apr 7, 2004
    2,977
    You may want to note that the US spec CS does not have the racing harness anchor points on the rear shelf.
  10. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
  11. PCH
    PCH F1 Rookie
    Apr 7, 2004
    2,977
  13. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,509
    Fred
    +1!!!
    US cars do NOT have the anchor points in the rear. In order to use the belts in a US car, you will need to have anchor points installed into the rear shelf/support bracket!!
  14. sezme
    sezme Formula Junior
    Oct 23, 2006
    553
    NJ
    sezme
    Is that hard to accomplish? Is it major surgery?
    S
  15. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,509
    Fred
  16. duskybird
    duskybird F1 World Champ
    Rossa Subscribed Owner
    Jan 20, 2007
    10,679
    29 Electoral Votes
    Bill B.
    That risk is more associated with 5 point (crouch/ submarine) belts.
  17. PCH
    PCH F1 Rookie
    Apr 7, 2004
    2,977
    Not necessarily hard but does require evasive surgery.
    As per factory, rear shelf fabric, (Alcantara or leather) gets removed in order to weld unobtainable factory anchors, (you'll have to fabricate them) to L/R side of the firewall. Fabric must be cut, (to allow harness pass through) then sewn and then covered with factory eyelets.
  18. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    I'm interested to know what "evasive surgery" is - perhaps the mechanic can only do it behind closed doors? Perhaps the CS is shy and doesn't like being undressed? :)
  19. PCH
    PCH F1 Rookie
    Apr 7, 2004
    2,977
    Fairly simple and typically used in medicine. Google it.
