Strange air fan noise in my 308 GT4 | FerrariChat
Discussion in 'Technical Q&A' started by olivier, Nov 21, 2005.
  1. olivier
    olivier F1 Rookie
    Mar 3, 2005
    4,973
    France
    Olivier B.
    Hi
    this evening I heard a very strange noise coming from the cooling air fan of my GT4.
    I think the fans don't work well as if the fan was in contact with something (the grill ?).
    Is it a already known problem for someone ?
    Is it necessary to change the fan (with the motor ?) or is it possible to put again the fan in the right axle maybe ?
    How is it possible to know if my air fans (both are doing the same or so) are close to death ?
    Many thanks
    Olivier
  2. Jdubbya
    Jdubbya The $10 Trillion Man
    43,665
    Hell's waiting room
    You can turn both fans on by removing the wires from the thermal switch (should be near the bottom of the radiator on the passenger side) and touching the two wires together (with the ignition key on of course). Maybe try having someone hold the wires together while you look to see if one of the fans is rubbing somewhere.
  3. nemrava
    nemrava Karting
    Jan 2, 2005
    61
    Ohio
    Joseph Nemrava
    Many years ago I hit a cat (he or she survived) but the cooling fan developed a "strange noise". The grill needed some re-adjustment. It is easy to remove it.
  4. olivier
    olivier F1 Rookie
    Mar 3, 2005
    4,973
    France
    Olivier B.
    Thanks for the advice
    The fans look old and tired. I think I will have to change them. The fan while turning was touching the front grill so much noise !
    Any idea for a non-Ferrari reference that would fit ?
    Olivier
  5. Jdubbya
    43,665
    Hell's waiting room
