348 - strange behaviour | FerrariChat
348 strange behaviour
Discussion in '348/355' started by raoulfilippi, Dec 29, 2023.
  1. raoulfilippi
    raoulfilippi Karting
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    I would like to tell you about a strange behavior of my 348. This summer after about ten kilometers from the start the car seemed to go into protection mode, it seemed to me that a bank was missing. After a while, let's say 15 km, the car started working again, but over a certain number of rpm the problem recurred. So I decided to take it to the mechanic to have it checked. he was never able to replicate the problem. I know for sure that it doesn't come from the Vescovini probes as mine is decat and these are detached. Has anything like this happened to anyone? Any suggestion?
    Thx
  2. ChoonHound
    ChoonHound Formula 3
    2,214
    Saint Michaels, MD
    Lucas
    Just because you don’t have a cat doesn’t mean that the cat temp ECUs don’t need valid data and can’t go bad themselves. It sounds like that’s the issue.
    Did your mechanic pull the codes?
  3. fatbillybob
    Aug 10, 2002
    28,955
    socal
    Some of us are the original owners of 348's and chased these 348 ghosts from the day they left the factory. What you describe is a typical intermittent failure caused by poor electrical connections.
    cavlino, 308 GTB and raoulfilippi like this.
  4. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Thanks, I suspected something like that. In fact, when the mechanic disconnected some connectors to connect his measuring instruments, then when he reconnected them the problem never recurred again.
  5. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    All my intermittent problems went away when I replaced all the relays.
    cavlino and FloridaIsland348 like this.
  6. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    Does he have a Ferrari SD1 tool? The ECUs should be detecting and recording faults.
    If you can at least identify the bank which is shutting down, you can always swap components from left to right. I will never understand why many Euro Ferraris don't have SDL and CEL warning lights.
    FloridaIsland348 likes this.
  7. fatbillybob
    Aug 10, 2002
    28,955
    socal
    There are solutions to chronic ghost chasing:
    1- unplug/replug to refresh connections (with or without bending of pins to increase contact pressure)
    2-electrical contact cleaners (with or without bending of pins to increase contact pressure)
    3-contact enhancers like stabliant-22 and de-oxit gold (with or without bending of pins to increase contact pressure)
    None of the above works for long but cheap and easy while inconvenient.
    4-partial and complete re-pin of harness with pins/connectors/boots/seals/
    This has been a permanent solution for many but is highly controversial as to what pins to use, whether this extreme measure needed, what it does to car value.
    cavlino, FloridaIsland348 and 308 GTB like this.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    #8 johnk..., Dec 29, 2023
    I have had similar problems with my 355. Once it was a bad coil which would intermittently cause 2 cylinders on one bank to die resulting in loss of power and change in exhaust tone. The fix was to replace the coil and the power module just to be sure.The other was a broken wire at one of the crank position sensors. At a certain RPM the vibration would cause a loss of contact and it ran like it hit and rpm limiter. Back off the throttle and it would run fine. That fix was repair the broken wire. There were no codes in either case.
  9. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,324
    Palos Verdes
    Vince V
    My car too occasionally suffers from this syndrome. As best I can figure it, the problem only appears after the car has been sitting for awhile and definitely goes away once it is properly warmed up. Driving it weekly seems to avoid or minimizes its appearance. I have chased this ghost for years. As much as I can tell, it has to come down to wiring since I pretty much replaced or serviced everything else. Our TCUs are pretty simple devices so their failure isn't likely. I need to swap my ECUs but I sincerely doubt these are the cause since I have 4 and have rotated them around before. More likely, as FBB suggests, it's either wiring or pinning. My issues seem to affect only the 5-8 bank. One day I'll repin the damn thing. My short term recommendation would be turn off the power and pull your ECU 50+ pin connector, then clean the contacts on both ends as much as possible. It's easier to actually remove the ECUs from their location behind the seats to do this. Apply a contact treatment. Then drive the car more often but make sure it's pretty warmed up in the driveway first.
    cavlino and raoulfilippi like this.
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,215
    Serbia - Niš
    Miroljub Stojanovic
    Did you only disconnect the probes (the Thermocouples) from the Vescovini Centralina or also disconnected the Vescovini from the car harness?
    If you leave the Vescovini still connected to the harness, it can cause bank shut-down if something goes wrong with it. It is better to completely disconnect the Vescovini and this will not affect the engine running at all. You will only get "silent" code 4121 but no CEL or SDL.
    cavlino likes this.
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    It's 55-pin Bosch ECU connector.
