Strange engine sound 328 | FerrariChat
Discussion in 'Technical Q&A' started by ducowti, Aug 5, 2008.
  1. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Car has previously run great for a few thousand mi, last driven 5 days ago. Just started it now and I hear this new rhythmic tapping/knocking sound coming from the right side of the engine, though I can't pin it down. Could not tell if its cadence increases w.RPM since I don't have another body to gas it. Shut it off, restarted and it persists. Took a couple vids, the 2nd of which you can hear it better w.the bonnet closed. In the 1st, it's more audible twds the end of the clip. It sounds a bit adulterated through the crappy video as it really sounds like tapping a wooden spoon on the bottom of an empty coffee can, w.a slightly more metallic sound than wood would produce. Make any sense?!
    Sound ominous? Like I shouldn't drive it? :eek:
    http://www.youtube.com/watch?v=ehbOost_bno
    http://www.youtube.com/watch?v=ay9P_j7i0b4
  2. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Well, I started it a 3rd time after posting and sound was not present. Gently drove it around the block stopping a few times to listen and nothing. Went for a longer drive to dinner and still nothing - which is good. I hadn't heard it before so was a little concerned.
  3. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,211
    Atlanta
    Tom Spiro
    I watched your videos...I think your ACC belts are making the noise. get some belt dressing from Pep boys, take off the air box and spray some dressing on the EXPOSED belts the one that is on the water pump. Most likely you should change the belts soon, but if its coming and going there is no rush. Mine do it when it gets cold out, or the car has set for a while... several weeks.
    It can happen all of a sudden, and sounds terrible... luckly its not catastrophic...
    cheers!
    Tom
  4. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    I can't quite tell from your video's. When was the last time you changed your accesory drive belt? Usually there is a metallic sounding noise when the belt gets older and it is cold. As the belt warms up this noise goes away. The belt apparently has some sort of plastic ribbon in it that gets old and less flexible over time. As the car warms us this platic ribbon warms up, becomes more pliable and stops making the noise. No biggie, but if these are symptomatic of what you have, you should change that belt.
    Alberto
  5. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Thanks fellas, sounds like what you're describing esp as it went away as it warmed. Coming soon: a thread from me asking how to change the belt :D
  6. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    You can easily rev the engine from under the hood. Just rotate the throttle where it enters the plenum. Look for the end of the throttle cable and rotate the part just as the cable would do.
  7. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    Uh, err, yeah I knew that. Can't believe I didn't think to do that, esp since I have lubed that more than once in the last few months :rolleyes:
    Thx :D
  8. spirot
    Dec 12, 2005
    15,211
    Atlanta
    Tom Spiro
    Not hard, just time consuming. If you are going to replace the belt, check to see if you need to do your water pump... search for a water pump replacement thread... that should give you the proceedure.... use the belt dressing for now, and most likely it will go away.
  9. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    Just curious if your ac is on or off when noise is present. A compressor can make some awful noises but I agree with other posters its most likley loose-worn belts. You can check pretty easily. Jack up rear of car, remove wheel and remove wheel well liner and all three belts are right there.
  10. Lawrence Coppari
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    One test you could do is to remove the belts, start engine and see if noise disappears. Then replace them one at a time to see which one is the culprit. Needless to say, I'm only talking fan belts here. ;)
  11. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    My 1980 308 has almost the exact same sound but not as loud. Seems to best be heard standing at 45 degree angle from the water pump and about 5 feet from the car. I noticed you had the camera at this angle.
