Strange no start on 328 | FerrariChat
Discussion in 'Technical Q&A' started by spirot, May 27, 2006.
  1. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    I have an 86 328... that has intermettent starting problems.... my mechanic came over the other day when it was not starting and traced all the wires.. from the fuse block and relays... and the issue was power between the relays and the pump... then pulled the relays in the foot well and found an old alarm system ... he disconnected the system and voila it started right away.... ran good for two days... then today no start... pulled the blue connectr on the metering unit and no fuel pump action... relays are clicking etc... WHAT THE HELL IS GOING ON!!! I'M STARTING TO FEEL THAT FERRARI OWNERSHIP IS NOT FOR ME... THESE CARS HATE ME!!!!!!!!!!!!!!!!!!!!!!!
    I have swapped relays & checked fuses etc.. all are good... I just have no freaking concept what is keeping this thing from working... and it works sometimes and then other it does not... why would that happen???
    Electrical issues confuse me totally....
  2. DGS
    DGS Seven Time F1 World Champ
    73,061
    MidTN
    DGS
    First, take a deep breath. Remember: even Ben Franklin managed to figure out electricity, in between chasing skirts. :p
    Look for a wiring diagram on the web (e.g. google for "ferrari document"), and then take another deep breath -- Ferrari wiring diagrams aren't the clearest in the world. (Hint: get a box of colored pencils to mark up a printout with the color code. Also learn colors in italian. ;))
    But if you get no fuel pump with the blue wire pulled (and the key on), then you've most likely got an issue on the pump itself, unless there was something in the old disabler system that the last service didn't extract.
    If you pull the left rear tire and wheel well, and put a voltmeter on the pump, and find 12v there, but no pump operation, then it's time for a new fuel pump.
    Did you run out of gas recently? Bosch fuel pumps are cooled by the fuel flowing through them. If you run out of gas, you risk overheating the fuel pump.
    You might want to check the car against the wiring diagram to look for things that the factory didn't install.
    The two most common issues with 328 wiring are (a) aftermarket stuff, and (b) the contacts on the edge of the relay board sometimes can't handle the current being run through them.
  3. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    Plenty of gas... over 1/2 tank .. drove fine last night... started right up... I checked all the fuses again ... and on the start valves there is no power with the key off... but is with key on... most all other fuses have power with the key off... can this be a fuse panel problem... checked the pump... no power there either with the key on... power at the relays... checked that ... and power at the fuel pump fuse... Frankly I dont know what to check... but this piece of **** is dead as a hammer! & I'm pissed off! everything else works ... I checked all the fuses / relays etc.. so I cant believe it would be a problem at the fuse pannel.... I've pulled all the pannels ... foot well etc... but dont know what I'm looking at ... and I cant find a electrical diagram for an 86.. I have one for an 89 but they are different cause the wiring colors are not the same... so either someone has been screwing with this before or its different!
    I'm aobut ready to sell this and get a new Porsche and call it quits with Ferrari
  4. carlrose
    carlrose Formula Junior
    Nov 25, 2003
    327
    Hi Spirot,
    I know it's frustrating right now, but hang in there. Besides, you now have a *reproducible* electrical fault and I'm guessing it happened in the best place, your own garage! (having changed a Chevy starter in cold rain on my back a few weeks ago, this is no small thing...!)
    Now will the car turn over but not start or will it not even turn over?
    I too have the '89 diagram, but I think 328s were very similar over the model run and would be surprised if wiring colors actually changed. Looking over, if you have power to relay there's two connectors behind the passenger footwell that transmit power from the fusepanel to the engine area. Pull your battery disconnect, then separate and inspect these connector to make sure none of the terminals have backed or are corroded significantly.
    This will be a good place to start. And they don't hate you any more than the rest of us. I promise.
    Best,
    :) Carl
    Saabguy likes this.
  5. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    I have all the footwell connectors out, and checked them.. I think .... seems like they are ok...
    I think this may be an issue with the old alarm system... but not sure... supposedly there was a white wire that went into the forward compartment infront of the foot well... but I cant trace it... I'll have to push the car out of the garage tomorrow and jack it up & see if that may be a problem...
    This is so frustrating....
    the engine turns over fine...when you disconnect the blue circuit at the fuel distributer ... the pump is not working .. I know there is power at the dist... so just dont know what is happening to the pump.... or how to trace it????????
  6. DGS
    73,061
    MidTN
    DGS
    I have an 89 and an 87 diagram, and the only significant difference is that the 89 has an extra diagram for the ABS system. Both match my '88 well enough.
    The stock operation of the fuel pump is a bit odd. The fuel pump only operates when the car is running -- mostly. Since this is a CIS system, if the pump operated when the car was off, it would be piling way too much fuel into the intakes.
    So it has a start relay and an AFM "safety" switch. When you turn the key on, relays "u" and "r" activate, and the fuel pump is off. When you turn the key to start, the start power from the key switch runs through relay "r" to activate relay "s" and turn on the fuel pump while the car is cranking.
    Once the car starts sucking air, the AFM switch (via that blue connector) removes ground and relay "r" deactivates, running ignition power to activate relay "s", keeping the pump running.
    If the car stalls, the AFM switch grounds, relay "r" activates, and relay "s" deactivates, cutting off the fuel pump.
    If you turn the key on, and remove the blue connector at the AFM, then the pump should operate (dumping fuel into the intakes -- don't continue long or the car won't start from too much fuel).
    When diagnosing electrical stuff, you have to be calm and methodical. It always seems hopeless until the answer jumps up and slaps you across the forehead. ;) Just take it a step at a time.
  7. loki
    loki Guest
    Jul 25, 2005
    227
    Are you thinking of selling it?
  8. Bandit
    Bandit Formula Junior
    Dec 21, 2003
    493
    Central MS
    Mike B.
    Since you've got power at the relays and the fuel pump fuse, but don't have power at the fuel pump, it sounds like a wiring problem between the relay and the pump.
    Give this a try. With the blue connector off the fuel distributor and the key on, grab the left most white wiring connector going into the fuse box and wiggle it. I had a problem similar to yours and it turned out to be the pump wire connector had gotten hot and lost contact with the fuse block. I heard the pump begin to run as I wiggled it and found the problem after I pulled the fuse block out from under the dash.
  9. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    Not quite yet... but Porsche is looking better and better ... I just bought this damn car two months ago...so I'm going to fix this some how and see how it goes... my tolerance is not very hi... I ve had 13years of Ferrari ownership ... and it has been less than stellar! I thought it was that I bought a bad car... now I think they all are like this!!!
  10. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    The problem has been found... I disconnected the blue connector at the fuel dist... and went probing... started at the fuse pannel... relays connectors.. then moved to the foot well... then all of a sudden started to buzz... hit the key .. voila started... so kept is running then started to gently wiggle wires.. then it stopped, wiggled more then it started... so I have it located at the 1st connector mounted on the bulk head behind the passanger foot board... I think its either the brown wire on the bottom or one of the 2 striped white & purple wires.. I think the diagram say those to to the fuel pump...so sprayed some wd40 in the connector plugged it back on and it ran ... then gentle tug stopped it.. so I need to trace the exact wire... but at least I know what's happening...
    I'm hoping the connectors are NOT a Ferrari specific item.... seems like the bottom one seemed kinda browner than all the others... coudl that be indicative of an overheating circuit?
    I also found out when you unplug the blue connector dont touch the white one at the same time... 12 volts does not feel bad.. but I woudl not make a habit of it!!!
  11. msouza
    msouza Formula Junior
    Mar 14, 2005
    292
    Tennessee
    Milton Souza
    Spirot,
    Congrats in finding the problem, but don't use WD40 to clean the contacts. WD40 is an oil, not good as a contact cleaner. Any Radio Shack store and most auto parts store sells a electrical contact cleaner.
    Regards,
    Milton.
    PS. I do have the wiring diagram for the 328, if you need one, just send you email via PM.
  12. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    Thanks for the post... but WD... I think was developed as an electrical conductor for NASA.... it is not a very good oil, but is a good conductor... anyway only used a small amount!
    I think I'm good on the diagram... thanks any way!!!
    Tom
  13. DGS
    73,061
    MidTN
    DGS
    WD-40: "Water Displacement, version 40". We used to dry plug wires on american iron with it, back in the stone age. But Radio Shack contact cleaner is better for cleaning DC contacts.
    Alas, the electrical connectors is one of the shortcomings of the 328. Those connectors are not completely unique to Ferraris, but they're hard to find anywhere except well stocked Ferrari shops.
    If you're good at finely detailed metal work, it's just possible to reshape the metal contacts (such as with a hemostat) to improve the connection temporarily. But as many of those connectors are carrying more current than they're properly rated to handle, the plastic shells will need updating from time to time. (When the white plastic gets brown, it's been cooked, and no longer has the intended flexibility.)
    I don't know where you're located, but Boston Sportscar in MA had stocked up on some of those connectors, a few years back.
  14. spirot
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    well its running ... but dont know ho reliable it will be... I need a new connector ... its the one in the foot well... 2nd one on the left.... you can see the small blue spark when it shorts... so what I did is tied it in place with zip ties nice and tight so it will not move... I'm sure this is only temporary... did I mention that you really need a midget to do this work!
    it was about 95* in the sun... could not fit it in my garage with the passanger door open... so pulled it outside... so freaking hot out ... I literally sweat about a pound of water out doing all this!
  15. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Just a thought: can you just splice a wire in with an inline fuse holder for the affected wire? It's a DPO (dreaded previous owner) repair for sure, but you'll be able to drive the car with confidence until a more professional repair is done.
    Ken
