Strange noise from my 348 today. | FerrariChat
Discussion in '348/355' started by Michael Everson, Mar 6, 2006.
  1. Michael Everson
    Michael Everson Karting
    Nov 5, 2005
    224
    Norton, MA USA Earth
    Michael Everson
    My car made a strange whine or muted screach twice today on the way home. Came from the engine compartment. Is my timing belt or some other belt doomed to fail? It only lasted less than a second each time and drove fine after that Not sure if I want to even drive it now. Heard too many horror stories. Is there any thing else that would make that noise back there. I have no idea when or if the belts were ever done.
    Thanks Mike
  2. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Sounds like your belts are slipping. They slip when they are wearing out, so I'd say you're getting a lucky warning that they need to be changed. Can't advise if it's timing or alternator, etc, but suffice to say it is most likely a non-toothed belt.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,944
    The Cold North
    Tom
    First off..a timing belt does not slip and make a squeaking noise as your driving. A timing belt failure will result in engine shut down..instanly.
    What you have is an accessory belt slipping. either the A/c belt or the alternator belt. You can access them from under the car once the rock garud has been removed.
  4. Michael Everson
    Nov 5, 2005
    224
    Michael Everson
    yeah I knew it wasnt the timing belt, but could have been a tension bearing or water pump bearing getting ready to fail. Where is the best place to buy a 30K kit to bring this thing up to date?
    Thanks Mike
  5. jjstecher
    jjstecher Formula Junior
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    Mike get your 30k from Ricambi on here. Dan can set you up with the right parts.
    Beyond that have my brake lines showed up yet? I dont trust UPS some times.
  6. Michael Everson
    Nov 5, 2005
    224
    Michael Everson
    Havent seen them yet but will watch for them Thanks for the advice on the 30K stuff
