Strange noise right rear | FerrariChat
Discussion in '308/328' started by rcraig, Mar 9, 2016.
  1. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    I have a noise that I originally thought was a cv joint going bad so two new cv joints and seal replacement from dif. That didn't fix it. It is a noise that happens after car is run for a while and a repeating even as you slow down etc. doesn't seem to happen when car is unweighted as I put it on jack stands and didn't happen. Although it might now have been run long enough.
    It's a whack-whack corresponding to wheel rotation. I know that's not much info, but could this be a wheel bearing?
    Definitely from wheel area. Can't find any obvious visual rubbing or interference from spring etc. it really does get loud.
    I know this is tough to diagnose on here, but any ideas?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    If you didn't replace the outer CV joint, it could be that or, you could have noisy wheel bearings.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,602
    San Carlos, CA
    Mitchell Le
    It is known that the rear wheel bearing can go bad
  4. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Mike. I replaced both cv joints on the passenger side. No luck.
  5. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Check that your wheel weights are not positioned so as to clip the lower suspension arm. I had rear left one that just kissed the suspension at made a tac-tac-tac sound, made worse when turning right. Drove me nuts as i thought it was something in the transmission failing... A shiny sction on the wheel weight gave it away. Peeled off and re glued elsewhere.
    Or check that the bushings at suspension arm meets hub aren't worn. I found one with play (slight perceptible rocking motion with wheel off and grabbing the disc). Also on rear drivers side (yes i changed this, drove 200 yards and had the sound still and the found the shiny wheel weight...).
  6. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Does it go away with brake application?
  7. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Thanks guys.
    Brian, sometimes?
  8. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Slip diff clutches make a noise at slow speeds and when the car is turning....
  9. B-26
    B-26 Formula Junior
    Jan 9, 2009
    301
    Glen Mills PA
    Jay
    Sure you don't have a nail in you tire.
  10. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,226
    Gold Coast, Aust.
    Patrick
    Are you sure it's not your hip?
  11. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    +1, you beat me to it.
  12. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    The hips are both gone, but I know that sound.
  13. jimgolf1
    jimgolf1 Formula Junior
    Aug 23, 2013
    375
    Reno, NV
    Jim Small
    I had a similar problem and it was a wheel weight on the inside of the wheel hitting the caliper.
  14. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Bad wheel bearings can lock up while driving (as a friend can testify as a bad one sent his car backwards into a hedge), so make sure you diagnose it quickly.
  15. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Thanks so much for all the input. I'll update when I find a solution.
  16. Jdubbya
    Jdubbya The $10 Trillion Man
    43,258
    PNW
    Bad wheel bearing is usually more of a groan and should go away or get better as you unload that corner.
  17. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,644
    SF Bay Area, CA
    Ruben
    +1 to check your tire... Sometimes a nail (or embedded rock for that matter) will me more audible at certain speeds depending on frequency. I've had that happen and the sound is as you describe.
    Cheers!
    Ruben
  18. 2281GT
    2281GT Formula 3
    Oct 9, 2006
    1,134
    Germany
    Markus
    I've redone the complete suspension on my car, all bearings, bushings, rubbers, brackets, tubes,washers, spacers,ball joints, shims, forks, nuts and bolts including the CV-joints, REALLY EVERYTHING under the car, but that noise is still there. I fear it's the differential.
    Next is to change the differential oil and ad an additive for "noise reduction".
    Question: please do not laugh, but has EVERY 208/308 a limited slip diff ? If not, how can I make sure, mine is one or not.
  19. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    Bob, 5 years passed in the meantime and I hope you can inform what was the cause. I seem to have a similar kind of issue?
  20. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    Change your motor mounts, that might be the issue, or the rear tires themselves. These cars are posi traction I believe . Both my half shafts are always transferring the power to the road, under load anyways, and around corners with the peddle down.
    Thank you
