Strange Oil Color | FerrariChat
Strange Oil Color
Discussion in 'Technical Q&A' started by kosmo, Jan 15, 2011.
  1. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    #1 kosmo, Jan 15, 2011
  2. Rifledriver
    37,089
    Condensation.
    Started happening the first winter after the invention of the internal combustion engine.
  3. ace_pilot
    ace_pilot Formula Junior
    Sep 6, 2007
    921
    Long Island, NY
    George
    Any coolant loss?
    Ace
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    It is definately water based. Not enough to tell if its coolant or condensation.
    Does it smell like coolant?
  5. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    just checked the coolant. its near the full line. It smelled like oil.
    whats do you think is causing the condensation, water? cold temps? Im a bit paranoid because I felt like the car is burning to much oil and of course VW says it's normal + at 48k miles the warranty is expiring soon. tks
  6. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    Yes Condensation.
  7. GRM
    GRM Rookie
    Jul 28, 2010
    24
    Greenville, SC
    Gary
    #7 GRM, Jan 15, 2011
    Coolant smells like oil.
    Oil looks milky.
    mmm milkshake... sounds like he busted his headgasket?
  8. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    It is condensation as stated before.
    Cold weather and the engine may not being driven long enough to drive off the moisture, which is normally there from moisture in the air and combustion.
    Don't worry about it too much. Short drives will make it worse, even long drives may not drive it off from your oil fill cap, but the rest of the engine is fine. Change oil at the normal intervals.
  9. CaptOharry
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    Do you live where the Humidity is high? My 06 Dodge ram did the same thing.I was told don't worry unless you have Fluid loss.
  10. JohnnyS
    Oct 19, 2006
    15,280
    Illinois
    I only see oil at the fill cap. What about the oil on the dipstick? Does that look milky?
  11. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    #11 kosmo, Jan 15, 2011
    the dipstick looks normal. I car is in HOuston and it normally very humid. But I wonder why its happening now??
    so in laymans terms, the coolant/water is somehow getting into the oil due to a bad gasket?
    Obvious this is not normal. Is there anything i can/should do or just take it in? Its still covered. tks
  12. JohnnyS
    Oct 19, 2006
    15,280
    Illinois
    #12 JohnnyS, Jan 15, 2011
    Even in Houston, it can get cool. I suspect short drives where the engine isn't up to full operating temp is the more likely cause. Nothing to worry about, just wipe it off.
    Coolant isn't the source of the condensation IMO because your oil looks okay on the dipstick.
    However, if there is oil in the coolant, get it looked at asap.
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Is the vw only driven for short runs (motor oil does not reach operating temperature)?
    You mentioned that your warranty is expiring soon.......just to be sure that you don't have a real problem here (bad head gasket) I would drain the motor oil and have a look at it.
    Pretty cheap way to verify what is going on here / have peace of mind.
  14. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Old trick: pull out the dipstick and hold a lighter under the oil on it. If it spatters, it's got water mixed in - much like a frying pan. That would be bad news. Some mayonaise like this on the filler cap is probably not a bad thing, especially if the car is not driven for longer distances. Never hurts to notify and ask the dealer though so the complaint is registered before the warranty period ends.
    Oh, and be careful - modern dipsticks sometimes aren't metal anymore but plastic. Said it was an old trick... Don't try this on a plastic dipstick.
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    LOL!
  16. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    I wouldnt stress about it. :):)
  17. f355spider
    f355spider F1 World Champ
    18,044
    Common. As previously mentioned, caused by cool weather, and short trips. Some cars are more suseptible than others. My gf 2007 Toytoa Tundra does it, although less so with synthetic oil. But she typically drives only 3 or 4 miles each way to work. A friends 2000 Durango V8 does it with synthetic too. Same, only drives 6 or 7 miles each way to work.
    If it concerns you, ask the dealer...but probably not much can be done. It is normal with "some" cars driven short trips in cool weather.
  18. tepps
    tepps Karting
    Oct 15, 2010
    103
    Buffalo NY
    Tom Tepas
    This is quite normal for many cars. 4cylinders moving up and down inside an internal combustion engine at 2000rpm moves a lot of air. As the engine is breathing the oil saturated air mixes with the humidified ambient air and coagulates at the top of the motor.Not a big deal.
  19. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    According to weather.com Houston expects a low of 54 tonight.
    If I still lived in Chicago and it was below freezing and I only used the car for short trips I MIGHT be comfortable with seeing that much condensate on my oil cap.
    If I were you I would absolutely, positively take the car to a dealer and have them look at it. Get something in writing that you suspect there is coolant in the oil and they say there isn't.
    That way if at 60,001 miles it becomes obvious that there is a big problem somewhere you will be covered.
    Definitely not worth the risk of just assuming it's condensation.
    Since I have lived in California the only time I have seen an oil cap like that was on an engine with a blown headgasket.
  20. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    A much more significant source of the condensation is from combustion. They hydro part of hydrocarbons (gasoline and diesel are two) combines with the oxygen part of air to make water (2 hydrogens and an oxygen = H2O) and give off a bit of heat. Most of the exhaust goes out the tailpipe and on a cold day you can see this brand new water condense in the air. A small portion of this exhaust gets by the rings and the water portion will condense on someplace cool. That's why the condensation in the OP's engine is at the cool filler cap but not visible on the dip stick in the hot oil. If you drove the snot out of it and got even the filler cap portion of the engine good and hot it would go away. And it's not a big deal if that minor amount hangs around.
  21. Cribbj
    Cribbj Formula 3
    If you want to eliminate the possibility of a blown head gasket, pick up a block test kit and test for the presence of combustion gasses in your coolant overflow tank when the engine is running: http://www.arrowheadradiator.com/head_gasket_or_combustion_leak_test.htm
    They run around $45-$50 from well stocked NAPA dealers, or you can order them from Amazon:
    http://www.amazon.com/gp/product/B000NPDL76/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B004FELK6A&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0JDCBA9FD8D0PD136AGV
  22. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,526
    Montreal Canada
    Bernie
    Sorry...couldn't resist. ;)
    [ame]http://www.youtube.com/watch?v=5ZxuWg9mXXo[/ame]
  23. Doctor7474
    Doctor7474 Formula Junior
    Jun 20, 2010
    367
    Hoover Al,former Atl
    Doctor
    Signs of headgasket and or coolant loss into the oiling system:
    Coolant in oil unkown at this point because you don't know if it's coolant in the oil or just condensation.
    Over heating?
    Running rough?
    Low coolant no per you.
    I would be willing to bet if the car is not running rough, is not over heating, and the coolant level is low you don't have a blown head gasket and this is condensation.
    Drive the car longer/harder to get the engine oil to operating temp for extended periods of time, short trips in cars where they do not get to operating temps long enough to boil off the condensation in the oil is a large factor in sludge build up.
  24. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Uh-- I gather the car is still under warranty.
    Is there a copay if you take the car in to be checked?
    If the answer is no, it is a no-brainer to me.
    Once I had Toyota Supra that was just about to go out of warranty.
    The power steering pump seemed noisy to me so I had them check it.
    They said it was OK.
    A few thousand miles later after it was out of warranty it was obviously failing and I took it back to them. They replaced it BECAUSE I had taken it to them before it was out of warranty.
    If your car were already out of warranty I would do the various things mentioned by others here, because its going to be on your dime either way. But its still in warranty, so why not take it in?
  25. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Due to what others have said.
    A byproduct of combustion is H2O, that's why it's so important to drive the car to full operating temp if you're going to start it. A long drive at operating temp will burn off the contaminants.
    If car is in winter storage, best to leave it sit until it can be driven. Fill the fuel tanks and put a battery maintainer on.
