strange sound on F355 | FerrariChat
Discussion in 'Technical Q&A' started by Pengster355, Mar 12, 2007.
  1. Pengster355
    Pengster355 Formula Junior
    Mar 9, 2006
    269
    Singapore
    Hi guys,
    Need your helps on this. I took the car for track day last week, it ran well, no problem through out (temps are okay and no lights came on) but it now has a strange noise which sound like it comes from the back of passenger seat while the temp is up to about mid gauge but it comes on and off. Im not sure how to describe the sound ... ttttrrrrrrrrrrrrrrr (if it tells you anything at all).
    The sound also stay for about 3-4 secs after I turn the engine off aswell
    Thanks for help
    P.
  2. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    If it sounds like it's "ticking" then you could have a header/s that is failing. It's a common problem with the 355's. If that is the problem you can get it rebuilt, or put on an aftermarket set of headers that are better than the stock units.
    But what you need to do first is find out for sure where the sounds is coming from.
  3. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    You mention the sound still occurs 3-4 seconds after the engine is turned off.....I think I would check the rear cooling fans.......try spinning them by hand first .....see if this is your sound.
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 one of the fan blades may be rubbing.
  5. Pengster355
    Mar 9, 2006
    269
    Singapore
    Thanks guys, will send it in to the workshop today. I hope its just a fan like you guys suggest. thanks again.
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Make sure you let us know what the problem is.
  7. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    x2! Or could be a fan failing......:):)
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 :)
