strange thing with the clutch | FerrariChat
Discussion in '360/430' started by beatbrother, May 4, 2017.
  1. beatbrother
    beatbrother Karting
    Aug 24, 2009
    181
    Zonhoven - Belgium
    Bart
    Last week something strange happened.
    I was driving in my F430 spider and I had to stop to make a turn.
    Suddenly it shifted automatically into Neutral.
    I tried using the paddles, but I couldn't put it in 1st gear.
    Then after 15 seconds or so, it worked to put it back in 1st gear
    This didn't happen to me previously, it was the first and only time and afterwards I didn't notice anything wrong.
    Is it something to worry about (bad clutch) or is it just something mechanic that could happen to all of us once in a while ?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,937
    Central NJ
    Dominick
    Hard to say ..did you check fluid level ..maybe it a tad low ? Just a educated guess
    Sent from my Moto G (4) using Tapatalk
  3. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    It will be an F1 issue of some sort that only an expert can cure. You may have to wait till there is a more frequent fault. Nothing worse than giving it to an expert who can't fault it. Worth getting it checked to see if it has stored any codes.
  4. LorenzoR
    LorenzoR F1 Rookie
    Can you tell us how many miles on the car since the last clutch was installed. It could be that the clutch is going bad or it could be the clutch position sensor. Either way your gonna have to get it in the shop for this one...
  5. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Sorry for obvious but.....you definitely had your foot on the brake pedal when trying to get 1st right?
    I only suggest as i stupidly did this till i realised first time out, using hand brake on hill, not used to autos
  6. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,281
    i have done this as well....
    if not that prob f1 pump
