Strange warm up behavior 308GT4 | FerrariChat
Discussion in 'Technical Q&A' started by Harry, May 23, 2007.
  1. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Recently, the GT4 developed a strange water temp gauge reading after start of the engine. Within the first 5 km of driving, the needle rises quickly but steadily up to 210-220F, then immediately drops to 160F and from there it rises in a normal pace up to 190 where it stays. Oil temp shows normal warm-up behavior (10-15 km until warmed up).
    This is quite new but occurs all the time. First I suspected the fuse box, but it did not change after overhaul of the box. Any ideas?
    Regards
    Harry
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Harry, it sounds to me like just an abrupt thermostat opening you are seeing. The thermostat stays closed until the water temp reaches a set point, and the coolant stays within the block. Once the thermostat opens, the coolant can circulate all the way to teh radiator. At that point, a load of cool coolant from the radiator gets mixed into the cycle, and the temp drops for a minute.
    Birdman
  3. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    You might want to burp the system to see if there is air pockets. Park with front end a bit lower than rear, then open the rad bleed screw. Even if cold you will purge air that way.
    Gerrit
    http://dino308gt4.com
  4. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Hi Gerrit,
    I always tried to have the front up to bleed the air at the radiator. Not correct?
    Regards
    Harry
  5. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Hi Harry
    I usually do this when cold. Because there is no pressure in the system I am asking gravity to help move the water downhill. This pushes whatever air is in the rad out.
    As with many things there appear to be multiple ways to do this purge. I used to do it when engine was hot, e.g. after a drive, but got tired of almost burning my fingers each time.
    Gerrit
  6. miked
    miked Formula Junior
    Feb 7, 2001
    909
    Cincinnati, Ohio
    I agree with Gerritv, those are the classic signs of air in the system. I usually have the car's nose up higher than the engine & expansion tank. Have the heater set to "Hot" as well. You may have to bleed the radiator a few times to get all the air out. Make sure that the expansion tank is full (when cold) before start up. Again, it may take a few cold/hot/bleed cycles to get it all of the air out.
  7. marankie
    marankie Formula Junior
    Aug 30, 2004
    252
    Agoura Hills, Calif
    Martin
    I agree with Gerrit.
    With a cold motor, park with the nose down (below the level of the radiator expansion tank), open the radiator filler cap, and open the bleed valve on the radiator. You need to open the fill cap otherwise you will pull a vacuum, and not all air will be burped out. Also gives a good opetunity to check fluid level.
    For me this is a ritual every time I take out the car.
    Opening the heater valve is also a good idea once in a while or with trouble some systems.
  8. 78-308gt4
    78-308gt4 Formula Junior
    May 22, 2005
    735
    Memphis, TN
    There are a variety of opinions regarding cooling system bleeding. I like the idea of bleeding a cold engine but what's the point of removing the expansion tank cap? With a cold engine the thermostat is closed. Seems to me this would negate any reason to remove the cap.
    FWIW I bleed the system with cap in place, heater fully on hot, open the bleeder valve ( I often hear the hiss of air escaping )then start the car. As the car warms, coolant expands forcing more air out. Shortly coolant bubbles out. I have a coffee cup modified to hang on the A/C lines by the bleeder valve catching the coolant. Once the engine warms to where the thermostat opens and there is a STEADY stream of coolant ( no bubbling or spurting ) flowing into the cup I close the bleeder valve knowing all the air is gone. I discard the coolant in the cup or add it to my daily driver's cooling system.
    Yes, I keep an eye on my coolant level and top it off when neccessary
  9. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    The reason for removing the cap (when cold) is to prevent or remove the vacuum that builds up as the air leaves through rad vent. The thermostat has a bypass hole so that some water will flow even with the thermostat closed.
    Gerrit
  10. 78-308gt4
    May 22, 2005
    735
    Memphis, TN
    ah, ok makes sense
  11. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    I agree with Gerrit, I have had this problem before, nose down for air removal and open the system at the rad and expansion tank.
    The behaviour is classic air pocket in the system have seen it a few times on my own car.
  12. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    On a gt4 any immediate needle movement on a gauge should be cause for concern..... :)
  13. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Thank you all, advices were spot on: topped up coolant, released air at the radiator bleeding screw, topped up coolant again. Now everything works properly.
    Regards
    Harry
  14. 78-308gt4
    May 22, 2005
    735
    Memphis, TN
