"STRATOS ENGINE GEARBOX UNIT, CONVERTED TO DINO 246E NEW" | FerrariChat
Discussion in '206/246' started by celestialcoop, Apr 17, 2011.
  1. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    #1 celestialcoop, Apr 17, 2011
  2. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    It looks like a normal Dino engine...maybe the heads were removed from when it was in Stratos form? I would guess the alternator (still showing),starter and distributor were stripped off and sold. It is very interesting if this one is "factory fresh" that the offset crank pulley has been drilled. I don't want to light that whole thread up again but supposedly all engines were externally balanced from the factory(so why the drill holes). It will be interesting to see where it trades.
  3. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    How would the factory balance without drilling holes?
    On two of the pictures you could still see the 40 IDF carbs (Stratos)
    the other picture has already the Dino 40 DCNF Carbs..
    How great is that if you can still buy after more than 35 years a NOS engine, wow...
  4. Eduardo
    Eduardo Rookie
    Nov 2, 2006
    1
    Hi Coop!!!
    Nice to found here :)
    Hope to chat soon...did you got my email?
    All the best from Portugal,
    Eduardo
  5. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    246 externally balanced, Ii crank was turned or heavier pistons installed, ie: cheaper then originals then holes or weight woulld have been added. balncing requires a computed bob weight installed on rod throws to accomplish. DO NOT LISTEN TO ANY ONE WHO QUESTIONS EXT vs INT BALANCING
    CLAY
