Stratos induction system on 246GT | Page 3 | FerrariChat
Discussion in '206/246' started by Pantdino, Aug 28, 2005.
  1. tx246
    tx246 F1 Veteran
    6,701
    Texas
    Shawn
    Alright.... We ALL need to find out about this........
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,257
    Norfolk - UK
    Tony
    with no plug leads that's impressive :))))
  3. dinogts
    dinogts Formula 3
    With this, not only do you not need sparkplug leads, you don't need hoses attached to anything either. ;)
  4. racerboy9
    racerboy9 F1 Rookie
    2,677
    The Stratos road cars have a water jacket in the intake manifold. Not sure what the reason is unless it prevents icing.
  5. stratos
    stratos Formula Junior
    Dec 9, 2003
    639
    Switzerland
    To make sure the intake air is heated to ~90°C hence being thinner and reducing power output?
    Ok I'll stop making cheap jokes, this is only present in the Stradale cars and most cars I have seen have it disconnected.
    Race cars with cross intake manifolds and 24V have no provision for this all others have it disconnected also.
  6. racerboy9
    racerboy9 F1 Rookie
    2,677
    Here is one rational from the internet for heating the intake manifold:
    "Hot coolant from the cooling system flows through the waterjacket and heats the manifold. Heating is required in a carbureted engine to provide better vaporization of the air-fuel mixture".
    Lancia must have done this for a reason. Certainly easier to cast a manifold without the water jacket. Maybe on a road car with more normal (non-racing) throttling it had some advantages.
  7. stratos
    Dec 9, 2003
    639
    Switzerland
    I would guess it's hot enough being in contact with the engine block and heads.
    The carbs depression reduces outside temperature by at least 20°C then the air gets in touch with the manifold and head but not long enough to get much heat out of them.
  8. rosso corsa motorsport
    rosso corsa motorsport Formula Junior
    Nov 30, 2008
    268
    yes this is the latest technology for revving over 5000 completely wireless system
  9. rosso corsa motorsport
    Nov 30, 2008
    268
    i use my magic pin to make the stratos carbs fit under the std lid
  10. rosso corsa motorsport
    Nov 30, 2008
    268
  11. rosso corsa motorsport
    Nov 30, 2008
    268
    #61 rosso corsa motorsport, Apr 29, 2014
    here is Another setup, this car is very evil, very fun to drive from 1000 to 8000 rpm on each gear its pure Music thanks to the blue ignition Cables.
    better than seex
  12. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,860
    Southern California
    Peter,
    Does this one also fit under an unmodified decklid? How much clearance is left?
    Freeman
  13. stratos
    Dec 9, 2003
    639
    Switzerland
    Did not answer the question: How much clearance is there between the horns and lid once the latter is closed?
  14. swift53
    swift53 F1 Veteran
    8,561
    E.S.
    Alberto
    Peter, possibly very close to sex:)
    Regards, Alberto
  15. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,860
    Southern California
  16. rosso corsa motorsport
    Nov 30, 2008
    268
    go back and read on post 60
  17. rosso corsa motorsport
    Nov 30, 2008
    268
    YES!!!!
    i have one other car i do this modification on for a customer with a real race Engine
    lid is standard on that one to
  18. rosso corsa motorsport
    Nov 30, 2008
    268
    maybe i have that soon
  19. rosso corsa motorsport
    Nov 30, 2008
    268
    Alberto
    sex dont last for 8 hours every weekend, and if it do you better ask your doctor what is wrong. lol
  20. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,860
    Southern California
    A stock looking system with stock air cleaner please! I wonder if there would be a gain in horsepower and torque or just better driveability cold or hot in all elevations and hard cornering?
    Freeman
  21. ODDY
    ODDY Rookie
    May 7, 2013
    17
    I have the Jenvey throttle bodies fitted to my Dino complete with coil on plug ignition and a ROTREX SUPERCHARGE various intercoolers and a Motec 800 control. 10psi boost makes 110 extra hp with standard internals, More than gives the local Testarossa's a run for their money.
  22. rosso corsa motorsport
    Nov 30, 2008
    268
    cool
  23. racerboy9
    racerboy9 F1 Rookie
    2,677
    #73 racerboy9, May 1, 2014
  24. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,860
    Southern California
    Pictures Please!!!
    Freeman
  25. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,860
    Southern California
    Details Please!!! Specs? Carbs? Type?
    Freeman
