Hi Members. On my 2005 360 spider there is a grey 2 pin square plug in the engine bay attached to the wiring lume under the RH throttle body and i cannot see where it should plug in. can any member help with advise as to what it is for please. Looking at the engine towards the front have placed it onto the chassis member for a better shot See attached picture, hopefully picture attaches, not quite sure how to do this? Thanks Kipper Image Unavailable, Please Login
That should connect to the vaccum solenoid right under the throttle body. There are some vaccum lines connected to the solenoid.
Thanks for your reply, The vacuum solenoid is located under the left side throttle body and has two similar plugs plugged into it 1 * Brown + 1* white. Under the right hand throttle body is where this plug comes from? any further guidance on this issue will be greatly appreciated. I dont know if there is a difference but my car is a Euro spec Thanks again Kipper
