Street/ Road suspension for 360 challenge | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by kasperss, Jun 23, 2024.
  1. kasperss
    kasperss Rookie
    Jun 21, 2024
    2
    Looking for advice on buying road-oriented suspension for a road-registered 360 Challenge car, ideally similar to the Challenge Stradale setup. From my research, I found two main setups: Intrax and Motion. Does anyone have experience with these setups?
  2. motion
    motion Formula Junior
    May 4, 2005
    584
    At the track
    Motion
    I'm looking for info on road registering a 360 Challenge car. My state, Montana, allows me to get a license plate for pretty much anything, so no problem there. Any input on what its like to live with a Challenge car on the street for weekend fun use?
  3. 360-Challenge
    360-Challenge Rookie
    Oct 8, 2013
    17
    Austria
    I have made a 360 Challenge road legal here in Austria. The original suspension is horrible to drive on the road due to the high spring rates and the low suspension travel. Especially when the car height is set up higher you quickly run out of negative bump travel.
    My solution was using a modified KW suspension. The shocks were rebuilt using spacers to reduce the negativ suspension travel. I also had to modify the brake ducts.
    This set works really good on the road and gives a lot of control and feeling which was not the case with the original Challenge suspension.
  4. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,569
    ESP
    Bas
    What did you have to change on the brake ducts? Close them off?
  5. tres55
    tres55 F1 Rookie
    3,556
    Canada
    dave360 likes this.
  6. 360-Challenge
    Oct 8, 2013
    17
    Austria
    The front brake ducts need to be modified to get clearance with the dampers if the ride height is setup higher for the road.
    Bas likes this.
  7. Bas
    Mar 24, 2008
    42,569
    ESP
    Bas
    Tthank you :)
