Stripped coolant drain plug | FerrariChat
Discussion in '348/355' started by drbob101, May 18, 2020.
  1. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I googled this but couldn’t find anything.
    The hex in one of my drain plugs is stripped.
    Tips on removing it?
    I know I saw some hacks on here of replacing the plugs with something more user friendly as well. Maybe Taz?
    Thank you
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    You can use a blow torch to heat up a flat head screw driver and insert the hot tip into the head to melt into it the tip of the screwdriver let it cool and you should be able to unscrew it.
  3. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Thank you. Wondering if I have enough room up there to get a short handled screwdriver into it
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Block or radiator? Hex plug sound like you mean block plug.
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Sorry. Block.
    Now the post about melting a screw driver into it makes more sense. I was scratching my head on that one.
    taz355 likes this.
  6. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    Yes I was thinking you meant radiator drain plug.
    drbob101 likes this.
  7. A348W
    A348W Formula 3
    Jun 28, 2017
    1,862
    North Wiltshire, UK
    exactly which plug are you referring to?
    generally speaking here are a few ideas....
    Hex plug...you can try a slightly smaller Allen key and a flat head screwdriver alongside it.
    alternatively you can use a bigger flat head to go across the corners of the hex.
    If there is room and the hex head is proud enough you can hacksaw a slot across it and either use a f****ing big flat head screw driver or a piece of metal bar.
    sometimes a torx socket can be used!
    none of the options are pretty. Just be careful
  8. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    One of the brass coolant plugs on the block. Space is really tight up there. I like the Torx idea. Just ordered a couple new plugs and I’ll try that when ready. Thanks
    A348W likes this.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Use the other side to drain the engine block for now. When your engine comes out of the car at service, that is when you go whole hog with drill, and bolt remover.
    308 GTB likes this.
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Thanks Mitch. That’s what I did. Radiators and right side. Ordered plugs but maybe just leave it for now as you said.
  11. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
  12. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  13. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    I’ve read about people welding nuts to frozen plugs (usually on a trans or diff) and then using a socket to break it loose.
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    no Bob that was for the drain plugs in the block and the oil drain plugs sorry
    Maybe that is what your talking about, not sure though
    I should have read everything
    I will see if I have the link
    Found it
    https://www.ferrarichat.com/forum/threads/355-major-with-some-upgrades.576995/#post-146009697
    Wade likes this.
  15. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,032
    NE FL
    Ken
    I'd be tempted to leave it in there until the next major.
    I suppose you could drill it, and use a extractor to get it out. But if something went wrong you'd be screwed.
    If you think you can get it out, and it's not seized, Johnk was right, use a torx, triple square, or similar bit and Hammer it in there and cross your fingers. Used WD-40 and some heat.
    Weigh it the risk (cracked block) with the reward
    308 GTB likes this.
  16. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I would be inclined to leave it alone until a major as others noted. Its not like you stripped the filler hole and have already drained the tranny fluid! I wonder if you could put some jB weld around the tool and let it set up overnight? That might give you just enough to get it loose. You back to work yet?
  17. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I’m inclined to leave it alone. I changed the coolant draining the rads and the other side. I’m sure it’s fine coolant wise.
    I’m swapping out the ac pump and that buggered plug is right there. I’ll stick a torx in there and see if I feel any love but I think that will be the extent of my mucking around with it for now
  18. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    763
    Vermont
    john truskowski
    I purchased a product from Stahlbus that is installed in place of the plugs that allows easier draining much like the one in post 11. It even comes with a hose connection to make draining less messy. :)
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Still not easy to get it in there without the engine out
  20. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Of course the "purists" will frown on this but I don't bother with the engine drain plugs. Too much hassle. I drain the radiators. That get more than 1/2 the old stuff out. Then I refill and run the engine to mix it up. Drain the radiators again and refill. That leaves about 15% of the old stuff in. If do it a 3rd time you would end up with about 6% old stuff, but I don't take it that far.
  21. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    #21 Kokose7en, May 20, 2020
    Get sockets like these. Need to find one that fits snug. It will take it right out as it will bite the head when you turn. They are called twist extractors, but could be called other things. The one pictured is made by Matco, but Snap-on makes it and many others.
