458 - Stripped titanium wheel bolt/hub - can the wheel hub threads be repaired/tapped? | FerrariChat
458 Stripped titanium wheel bolt/hub - can the wheel hub threads be repaired/tapped?
Discussion in '458 Italia/488/F8' started by FerrariCognoscenti, Apr 10, 2022.
  1. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Not sure what happened but after swapping wheels today I ended up somehow stripping my titanium wheel bolt! It won’t go fully into the hole and when I unscrewed it half the threads were messed up! The threads on the inside of the hole on the hub are also messed up. Ugh.
    What is the fix for this? Is there a way to restore the threads on the hole by tapping them? What size tap? I’m going to order a new titanium wheel bolt but my biggest concern is about the stripped threads on the hub where the bolt goes into and repairing those threads. Is the wheel bolt also salvageable somehow?
    How do I fix this?
    Pics…
  2. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    639
    Austin, TX
    Looks to me like they simply got over tightened. I’d say it’s lucky you were able to remove them. The hub seems to have won so you should be able to clean the Ti debris out of the threads with a chaser or tap.
  3. Viperjoe
    Viperjoe F1 Rookie
    I'd try chasing the threads on the bolt as well as the hub (although the bolt may well be too far gone).
  4. timba
    timba Formula Junior
    Aug 20, 2012
    258
    Nor Cal
    Tim
    Just wondering...Were the Ti bolts from Ferrari, Hill Engineering, or eBay/other?
  5. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    They were from Hill Engineering.
    I ordered a M14 tap for the hub as well as die for the bolt. Hopefully this is recoverable!
    They arrive tomorrow so I’ll report back.
    timba likes this.
  6. PMiranda
    Jul 23, 2004
    639
    Austin, TX
    Those bolts are toast. Does hill provide a torque recommendation?
  7. fatbillybob
    Aug 10, 2002
    28,982
    socal
    TI is softer than Steel. The steel hub might be OK. It is possible that you got a shard of aluminum of the wheel or Ti from the bolt galled into the steel hub. Sometimes this can almost weld the part together where destruction is the way to recovery. Use no force in the future and you should be OK. Honestly this is a very rookie move. Not to insult you but wheels and wheel torque are important things especially with a car capable of nearly 200mph. As a racer we take great pains to keep our wheels on the cars and it isn't as simple as it may appear.
    Using a tap is a good thing but it must be done with gentle knowledgeable hands. To not only get the tap through properly but ensure that the hub is not destroyed. 4 good lugs on a 5 lug pattern isn't enough. Once you get the tap though hopefully it is just cleaning out aluminum or Ti and not cutting steel. After the tap I would carefully visually inspect the threads and screw in a good Ti lugbolt and compare what that feels like to the other holes. If this cut hole is hogged out and bolt has play in the hole that hub is done. If the hub hole passes then bolt on a wheel and see if you can get to torque. The wrecked Ti bolt goes in the trash. You aren't saving that.
    Read up on using a tap. There are critical things like using a light tough, proper cutting oil, insert some to resistance and back out and clean the tap, rinse and repeat. You can destroy a hole chasing it with a tap if you do it wrong. Before you put a tap to it I would use a sharp 120 to 90 degree pick and run it through the hole threads because it can't cut but it can pick out and dislodge a dissimilar metal smeared on the steel. Once clean see if you can passively get a lugbolt through. You are less likely to cause damage that way.
  8. WorKeDiT
    WorKeDiT Rookie
    Dec 9, 2021
    13
    VA
    Melvin M
    Informative post, I have the Hill engineering Ti bolts also. Will be checking the torque specs soon when I install my new wheels. Good luck on the repair!!
  9. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    Huge thanks to HBI Auto…Ferrari independent shop in NC who was at VIR for the Ferrari Club track day. They repaired the threads on the hub with no issue, the bolt was unsalvageable, and they even had a spare set of titanium bolts to throw in to get me through the event and not miss a single session.
    PMiranda likes this.
  10. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,421
    Santa Clarita, CA
    When you reinstall or remove the lug bolts, do it by hand. Don’t use an impact, even to spin them down until snug or remove them. If you do them all by hand you’ll be able to feel if one of them isn’t right.
    Rrr1, Rexcat458 and RoadRonin like this.
  11. xBox
    xBox Formula Junior
    Aug 16, 2018
    515
    The Emerald Isle
    Glad you got it sorted and only for the cost of new bolts.
    I would have been so mad at myself.... would have thrown my torque wrench at the windscreen, or something similarly unproductive :eek:
    Extreme1 likes this.
