Stroke on a 308 2v.... | FerrariChat
Discussion in 'Technical Q&A' started by etip, Oct 17, 2007.
  1. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    My motor is torn apart and I'm going to order the new pistons shortly; I have the head cc, head gasket thickness, and an old piston to send to Weisco to get some new, custom 10:1 pistons made. I believe I need the stroke or cyl. volume. Is it the same on all 308 2v or Do I need to bolt some parts back together to get this?
    Thanks for the help....
    etip
  2. DGS
    DGS Seven Time F1 World Champ
    73,078
    MidTN
    DGS
    I believe it differs between the US and Euro spec engines.
    The data should be in the 308/QV/328 workshop manual.
    (Due to a disk crash, I don't have my copy handy. (It's backed up to CD somewhere.))
    But the specs differ for different destination models. Is this a US edition engine?
  3. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Yes, it is a US car; 1980 GTSi.
    Thanks for the info
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    All 308s have an 81mm bore and a 71mm stroke.
  5. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Euro also! (right?)
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    ALL 308s, even euros.
  7. 308tr6
    308tr6 Formula Junior
    Dec 23, 2003
    466
    SDakota
    Rico
    Assuming you can bore a 1980 cylinder (not sure about this), you obviously need to consider that volume change in your calcs. I assume someone has calculated this...for typical overbore increments. Or perhaps you are just installing new spec liners?
  8. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    If the block hasn't been decked, what is the volume when the piston is at TDC? I thought I read something about 52cc, but I'm not positive. Anyone know??
    Thanks again for all the help.
    etip
  9. DGS
    73,078
    MidTN
    DGS
    I've only got the tech specs for the QVs and 328, but online I found, for an '80 308 (not sure what model): bore 81mm, stroke 70.9mm, compression ratio 8.8:1.
    (On the QVs, the specs are 81mm bore, 71mm stroke, CR = 9.2 (euro), 8.6 (us))
    Doing the math on the '80 2V, I get a per-cyl TDC volume of 46.8 cc (or 46.9, using the 71mm figure).
    (displacement / ( compression ratio - 1 ))
    ( CR = (Vbdc/Vtdc) = ( X + displ / X -> X + pi * (bore/2)^2 * stroke)/(X),
    solve for X -> X = displ / (CR - 1) = (pi * (bore/2)^2 * stroke) / ( CR - 1 ) )
    (divide bore and stroke by 10 to convert mm to cm)
    Although that leads to the question of whether that "compression ratio" figure is derived, computed, or measured. (The actual degree of compression in the engine will likely depend on valve timing, RPM, and inertial of air flow into/out of the engine.)
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    That's what I'm talking about:)
  11. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    No kidding. That's why I love this site.... Talk about some info!
