355 - Struggling with Intermittent 1211 codes and failed smog | Page 2 | FerrariChat
355 Struggling with Intermittent 1211 codes and failed smog
Discussion in '348/355' started by GatedF355GTB, May 8, 2024.
  1. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Did you smog the car?
  2. GatedF355GTB
    GatedF355GTB Karting
    Dec 5, 2017
    227
    SF Bay Area
    Joe
    Yessir. Passed smog today!
  3. radlu
    Jun 6, 2005
    424
    Hi Joe,
    Can you post the passing numbers/smog report?
    Thks
  4. GatedF355GTB
    Dec 5, 2017
    227
    SF Bay Area
    Joe
    Here you go:
    SoCal1 likes this.
  5. radlu
    Jun 6, 2005
    424
    So you went all the way from 8.30% CO down to .02% CO just because the bypass valve wasn't getting vacuum?
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Looks about perfect for these NICE !!!!!
    GatedF355GTB likes this.
  7. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    763
    Vermont
    john truskowski
    A little confused (again o_O) 95 with a 2.7 and you applied vacuum to the bypass valve to CLOSE it? I'm pretty sure my bypass valve is normally closed, and needs the solenoid to apply vacuum (under the right conditions) and open it. I can clearly understand that an open bypass valve will cause tailpipe emissions to be elevated.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    John, you must have missed that it has a Capristo bypass valve.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Block it off for testing
    also you did not mention your cats if they cool off too much it also causes problems on the 25 test\
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Responded before reading great you got it solved
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,690
    San Carlos, CA
    Mitchell Le
    I saw a lot of weird stuff on 2.7 355 and 348, but this is a very obscure case. Good going Tim and Michael.
  12. jjtjr
    Aug 29, 2016
    763
    Vermont
    john truskowski
    Ok. So the Capristo is normally open and uses vacuum to keep it closed?
  13. Qavion
    Qavion F1 World Champ
    14,604
    Ian Riddell
    Correct. It failsafes to open, to protect the engine.
  14. yelcab
    Nov 29, 2001
    13,690
    San Carlos, CA
    Mitchell Le
    I don't know if it protects anything. 90% of 355 do not have Capristo and the stock valve is reverse of that.
    radlu likes this.
  15. GatedF355GTB
    Dec 5, 2017
    227
    SF Bay Area
    Joe
    Yea, I’m not a big fan honestly. My other car has the stock valve which I prefer.
  16. Qavion
    14,604
    Ian Riddell
    I heard that that's why all later cars have Capristo-style valve/control logic (360, 430, etc). Wouldn't you get a greater heat build up in the exhaust system if the bypass didn't open at high rpm?
  17. yelcab
    Nov 29, 2001
    13,690
    San Carlos, CA
    Mitchell Le
    The function of the capristo valve open/close is the same as the stock. Meaning, the path is open when RPM is above 3000 RPM and is closed below that. How it is opened or closed with or without vacuum is reversed.
  18. Qavion
    14,604
    Ian Riddell
    Does the Capristo valve open if electrical power is lost?
  19. yelcab
    Nov 29, 2001
    13,690
    San Carlos, CA
    Mitchell Le
    Yes, it is normally open. It requires vacuum to close at idle.
  20. Qavion
    14,604
    Ian Riddell
    So, in essence, the Capristo system does behave in the same way as the 360 system. No power or vacuum = open.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Not sure what ferrari is thinking but I like that way
    Mine actually has two valves one on each bypass and it closes extremely quickly after start up I would say less than 5 seconds
    I have had 2 vacuum leaks and I knew before even taking the car for a drive which was nice as far as I was concerned
    any owner who does not realize their valve is not working likely does not drive hard enough that protecting the engine if that was true would not matter
    It is totally obvious I think to most of us but who knows for sure
