355 - Stuck 355 alternator bolt | FerrariChat
355 Stuck 355 alternator bolt
Discussion in '348/355' started by Red_SLR, Aug 3, 2021.
  1. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
    Anyone got any suggestions on how to remove a stuck alternator lower bolt?
    So far tried heat, a very long bar, an even longer bar, swearing at it and WD40.
    Its stuck solid - car is on a lift - next option is to cut it off but worried about the sump?
    Kokose7en likes this.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Impact wrench and extensions? My battery powered Ingersol Rand impact does 1800 ft lb. Breaks everything loose. The impact action is very different than a breaker bar.
    Snapped the frozen CV bolts below like they were never tightened, did not even have to mess with pb blaster and soaking them etc..
  3. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
    I dont think there is room for a gun really. Its quite tight. Thanks for the suggestion though.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Extensions and swivels are useful, gun is outside for alternator, in theory at least.
    Perhaps take slight tension off it with a small floor jack?
    Good luck!
  5. Ferrarista98
    Ferrarista98 Formula Junior
    284
    Jason L
    try tightening 1/8 of a turn before trying to loosen. a stronger penetrating agent than WD40. getting a long extension / bar on the bolt head and hitting the other end with a hammer. some combination or all of the above. good luck.
  6. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    925
    Europa
    Bob
    Not trying to be a smart a$$, but you know there are two nuts on the front of that bolt, right? Take those off completely with a spanner and the lower bolt should just come straight out.
  7. spaghetti_jet
    Jan 5, 2005
    925
    Europa
    Bob
  8. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
  9. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
  10. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    Long bolt Stuck solid? Won’t even spin with the nut off and a breaker bar?
  11. spaghetti_jet
    Jan 5, 2005
    925
    Europa
    Bob
    If you’ve got the top bolt out then I’d be giving the alternator a wiggle up & down until that lower bolt starts to move. Getting the top bolt out will help, if you haven’t already done it.
    Also, my car is a 2.7 and I don’t have the spring, but looking at the parts fiche it looks like the spring has maybe been fitted on the wrong end of your bolt? Perhaps someone with better knowledge of that bolt on the later cars will chime in and advise if the spring goes on the nut end or the bolt-head end…
  12. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    That sucks. I am a big fan of Kroil oil and heat. But its going to hard to get oil into the alternator mount. guess you could sacrifice the alternator as a last resort by cutting trough the mount.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    Spring goes on the bolt head end. I am not sure what to tell you about that bolt being stuck. Get a cheater pipe and use more heat.
  14. fatbillybob
    Aug 10, 2002
    28,980
    socal
    Put sacrificial nut on thread end to protect threads give a sharp wack with hammer or air hammer.
  15. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    Where does that bolt thread in? I assume on the mount side that's farthest away from the bolt head? I would heat wherever the threads are and hit it with cold water (spray bottle) to cool it rapidly. Do it several times. This rapid expansion/contraction can break up the corrosion enough to get the bolt free.
  16. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    That bolt does not thread into anything with the 2 nuts removed. I have an idea, try hitting the head of the bolt with brass hammer, or air hammer/chisel. The impact will compress the spring and hopefully free up any corrosion inside the hole where the bolt goes through.
  17. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,016
    NE FL
    Ken
    Before you start hammering... I would make sure you can find a new sump in case the worst happens.
    If it was my car, I would continue to soak it with WD-40 or whatever, and I'd use a propane torch to head the sump around the bolt, and then keep trying to turn that bolt.
    Hammer would be a last resort as it would definitely increase the risk of you breaking the sump. I would even say that using a breaker bar carries a risk of breaking the sump. The best thing you can do is get an impact on that. They do sell swivel impact sockets that in my opinion would be your best and safest bet.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,753
    Lake Villa IL
    How much heat did you try? I would put quite a bit into where it passes through the alternator.
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Soak with vinegar.
  20. spaghetti_jet
    Jan 5, 2005
    925
    Europa
    Bob
    Looks like you’re suffering a bit of galvanic corrosion.
    Rock that breaker bar back & forth. Give it some wellie with plenty of penetrating oil. Don’t worry, you’ll get it out.
    Giving the bolt a few whacks as has been suggested won’t do any harm. You’d have to be going some to damage the sump.
    Give it a good smear of copper grease when you reassemble it to help next time you need to dismantle it.
  21. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
    Thanks guys, its sorted now. The shop (indy Ferrari shop) got it off the following day. They used a set of mole grips on the threaded end and used them to wiggle and then hit it with a fine adjuster as they went and its off and all sorted. I think they also cut the spring and liner off the other end.
    There is actually a sleeve that runs inside the bracket and this had grabbed the bolt.
    Luckily I had a new bolt so it was all sorted with new spring etc.
    They also replaced the earth strap.
    I am sooooo glad I did not attempt this myself in my garage!!
    lanab and Qavion like this.
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  23. 32 Ford
    32 Ford Karting
    Jan 31, 2021
    175
    vancouver
    Mike McGowan
    Use anti seize compound before installing. I use that sh....on everything!
    GTO Joe likes this.
