stuck 398 oil filter | FerrariChat
Discussion in 'Technical Q&A' started by Doc, Dec 21, 2003.
  1. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    I am unable to get my oil filter off ! It is a Baldwin and was installed apprx 2k miles ago. I've used a rubber strap type wrench and a standard metal band-style oil filter wrench--and they dented the side of the filter instead of turning it. It just won't budge. Since the filter is smooth, I can't use one of those end wrenches which allows the use of a ratchet handle.
    Any suggestions re: other wrenches/ techniques for getting this sucker off ? I'm concerned about the filter totally collapsing if I keep trying with my wrenches . It's very cold where I am--would heating it up a bit with a small electric heater help? What do think about those pump-plier type filter wrenches?
  2. speedmoore
    speedmoore Formula 3
    Apr 15, 2003
    1,541
    Austin, Texas
    D Moore
    348, I assume.....take a phillips screwdriver and drive it through with a hammer. That should give you some leverage. I have a huge pair of channel locks that has never let me down too. But you probably don't have that.
    BTW, I usually punch a hole in them with a screwdriver and let it sit for a minute anyhow to help the remaining oil in the filter drain out before I remove it cutting down on the mess.
    d
  3. Jerry Fisher
    Jerry Fisher Karting
    Nov 1, 2003
    75
    I use one of the plier type w/ wide mouth.
    Gives much more leverage and worth the investment. Hopefully its not cross threaded.
  4. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    Oops--i have a 308, not a 398! It seems that the plier-type remover is best. I'll pick one up pronto. thanks, fellow tifosi !
  5. fatbillybob
    Aug 10, 2002
    25,688
    socal
    Doc,
    It is totally ok if you crush the can with your tool or hammer a screw driver through and crank it off.
  6. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    Sorry to state the obvious but ......righty tighty, lefty loosey.
    Tom
    p.s. Unless you're south of the Equator. :)
  7. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    Well, i got myself a nice jagged-toothed, pump-plier-type of filter wrench and it came right off. Thanks for the assistance--and Happy Holidays!
