Stuck allen screws for rear calipers!!! | FerrariChat
Discussion in 'Technical Q&A' started by barcheta, Aug 22, 2006.
  1. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    The outboard ones are no problem... but the inboard ones are a PITA... I don't want to strip the 4mm opening so what else can I use to turn these to compress the piston? Thoughts?! TIA
  2. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    #2 Steve Magnusson, Aug 22, 2006
    Stripping the female hex drive on those rear inboard caliper plugs is a common problem. If completely stripped, you'll need to either file/grind a groove into the head of the plug to use as a drive feature or whack the edge of the plug with a punch/chisel to try to rotate it CCW.
    Once you get them out, replace them with the Porsche 914 part PEL-BRC-02 from www.pelicanparts.com (which has an external hex drive head):
  3. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I have one word for you -- Kroil. It's amazing stuff. Much better than PB Blaster, Liquid Wrench or any of those things. Shoot some Kroil on the bolts and let them sit for a few hours. Do it a couple of times and the stuck will come unstuck. Trust me, it works.
  4. BabyFerrari
    BabyFerrari Rookie
    Aug 22, 2006
    40
    PA
    anonymous
    sears sells a set of "sockets" for stripped bolts. buy them, they are like 20bucks and work great
  5. thecarreaper
    thecarreaper F1 World Champ
    18,071
    Savannah
    we use "Aerokroil" on really corroded aircraft parts during heavy service work. it is the best stuff i have ever seen in action period. even dissimilar metal and galvanic corrosion are no match for the stuff.
  6. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    I don't want to hijack the thread, but I was having some problems with my 308's rear calipers. It seemed that the e-brake was sticking on. The inner pad on the driver's side was worn to the metal. The guy at the shop said it was a common problem and my caliper needed to be rebuilt. Well, after about 1k of work performed, as soon as I used the e-brake, you guessed it, it stuck on. Obviously not a caliper problem. Do you think it's just a cable problem? I know that to retract the pads you need to undo the cap (on the outside of the caliper) and then the retaining nut and back the screw off, but, is there the same adjustment for the inside portion of the caliper?
  7. Steve Magnusson
    26,822
    #7 Steve Magnusson, Aug 24, 2006
    Yes -- after removing the inner threaded plug shown in the figure, there is a free-floating pinion gear piece with a female hex drive (3~4~5mm?), that when turned, moves the inner piston in-and-out (but not sure how, or why, this adjustment would affect "sticking" if present):
