Stuck bonnet on a 456 | FerrariChat
Discussion in '456/550/575' started by nettwerkjohn, Nov 28, 2017.
  1. nettwerkjohn
    nettwerkjohn Karting
    Mar 6, 2015
    114
    Waikawa, Picton 7220
    John Phillips
    hi guys
    My bonnet is stuck down after I replaced a broken bonnet pin.
    Was adjusted as far as possible towards the outside of the car when I installed the replacement, but was still a "snug" fit when I closed the bonnet. So snug that it now won't open at all.
    Any ideas on how to open?
  2. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    My car isn’t here right now to double check, but I think if you take off the front grill, you can reach the latching pin and release mechanism.
    Good luck, and be thank full you don’t have an old Triumph, or you’d be unbolting the entire bonnet.
  3. stardoc
    stardoc Formula Junior
    May 5, 2005
    669
    The big oven
    K RA
    This happened to my 550. Killer is correct about reaching the latching pin through the grill, but the trick that worked for me was to push the hood down on the stuck latch area with force and have someone simultaneously pull the hood release from inside.
  4. nettwerkjohn
    Mar 6, 2015
    114
    John Phillips
    Guys
    I got in through the front, knocked the original pins free, and up she popped.
    Let's just say, I am now a master of adjusting the pins for fitment. What a pita it is.
