stuck front trunk, 84 308gts | FerrariChat
Discussion in '308/328' started by LarryS, Apr 13, 2006.
  1. LarryS
    LarryS Formula Junior
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    My 84 308gts front trunk(?) will not open. The latches do release and the lid raises a little, but then something binds after about 2 inches. There in no interference between the body and the lid, all gaps look good, worked fine a few days ago.
    Any opinions appreciated....
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Could the gas strut have failed in some way to freeze up?If you can block the lid open, perhaps you can reach down in with something to pop the strut off the ball. Otherwise you would probably have to go up from below, but access may be difficult. Also, you may get access to the strut through the headlight grille opening after you remove it (four screws). Good luck, and keep us posted.
  3. LarryS
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    Sounds like you've familiar with that area, it doesn't look to promising from the bottom. It seems like the right hinge is binding, the strut seems to be moving. I might do nothing and see if it fixes itself (fat chance huh), as long as I don't need to get to the battery, spare tire or CD cassette....
  4. LarryS
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    sprayed a lot of kroil penetrating oil around the hinge pivots and slowly worked the hood up and down, it finally freed up and again works fine. Wouldn't hurt if you guys lubed up yours.... Larry
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    ????? All it needed was some lube? Wow, who woulda thunk it.
  6. LarryS
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    I was surprised also.
