STUCK IN REVERSE GEAR ANY IDEAS | FerrariChat
Discussion in '348/355' started by fioranotestpilot, Aug 16, 2006.
  1. fioranotestpilot
    fioranotestpilot Formula Junior
    May 20, 2005
    262
    australia
    andrew pontone
    hi guys just back from a 2 day concours, car has been running near perfect 2 years but yesterday was engaging reverse and it got stuck and wouldnt come out, had to switch of engine and depress clutch and pull hard. any ideas before i go rushing to the mechanics, after that no problems changing gear while driving
    andrew
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    It may just be loose linkage. Try checking the shifter coupling under the car. Have somebody move the shifter while you look at it under the car. Make sure the shaft rotates. It is located just inboard of the parking brake cables.
  3. PAP 348
    Dec 10, 2005
    100,219
    Mount Isa, Australia
    Pap
    Is it hard to get any gear now Andrew? Or was it just reverse gear yesterday? A one off......:)
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    If it isn't the shift cables then you may have a worn syncro.
